    3,443,311
Frigidaire Gallery top load washer burning belts, won't agitate
Hi,
I wonder if It needs to be replaced? The washer does not agitate, and when spin cycle comes around, the motor turns counterclockwise, but the belt & big pulley is locked or frozen. Howerver, to turn the belt by hand clockwise, it turns freely.
What would cause this problem?
http://www.repaircli...mber=FWS777GHS0
Yes, the transmission. You will also need to replace tub seals and belt.
Source: burned in belt fridgidaire gallery washer FWS777GHSO
