    3,442,987
Condenser fan in a GE refrigerator runs slowly, compressor hot; how to test the condenser fan
Check the voltage going to the condenser fan, should have +12vdc on the red wire with your common probe on the white wire. Make the measurement with the fan connected. Easiest to check it at the muthaboard. See this reference:
If you have a good power supply to the fan, then replace the condenser fan motor ==> http://www.repaircli...4X10055/1093723
More background info on GE fan motors here ==> http://appliantology...-and-condenser/
Source: Condenser Fan running slowly. Compressor very hot. '05 GE bottom mount.
If you like this post, please share it using one of the buttons below. Domo!
