    3,443,275
How to clean the accumulated scale and crud out of a dishwasher so it can clean the dishes better
Remove the spray arms.
Soak them overnight in a tub of CLR.
With the spray arms removed,run the dishwasher so that water circulates without being restricted through spray arms.
This may dislodge some crud that can be wiped out.
Re-attach the arms and start the unit.
Once it fills and starts washing add 1 quart of white venegar to the water and let it compleete the cycle.
Glisten dishwasher cleaner and scale remover ==> http://www.repairclinic.com/PartDetail/Dishwasher-Cleaner/5304482929/1915432
Source: GE dishwasher leaving crud on dishes GLD5950N00CS
1 Comment
tommytech
do you use d/washer magic or lemishine for this problem?
