  2. See if this is want you are looking for:
  3. Manufacturer: Samsung Type of Appliance: Washer Model Number: Wd53ba900hz Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need disassembly instructions for this Samsung washer. Replacing a door boot. thank you.
  4. Today
  5. jason.arthur.taylor.1
    Samsung RF20HFENBSR fridge 3 door
    Please include units.
  6. Thanks for checking!
  7. Samurai Appliance Repair Man
    Great choice! @Nathaniel Peterson thanks for bringing your experience and expertise to your fellow Appliantologists! We are enriched because of skilled techs like you sharing knowledge and helping out fellow techs.
  8. " below the evaporator coils " sorry I meant condenser coils there. Unable to edit perhaps because I am so new.
  9. Nothing here!
  10. Ananda
    Whirlpool WDF540PADB3 Dishwasher Tech Sheet
    Also applies to model: IUD7070DS*
  11. Uses these docs:
  12. @Vance R or @Captain Dunsel, either of you fine fellows have a manual for this model?
  13. Brother @Vance R, do you have anything for this one?
  14. Manufacturer: Miele Type of Appliance: Dishwasher Model Number: G2141SCU / G 2141 SCU Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Miele G2141SCU / G 2141 SCU dishwasher service manual request Thank you
  15. Captain Dunsel
    GE fridge freezer warm
    You should be able to use this mini manual: May have some similarities to Parts of this manual:
  16. Manufacturer: GE Type of Appliance: ref Model Number: PFSS5NJWA Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Y Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Y Customer with GE frige says freezer is warm. Fans seem to be running but cannot verify Compressor. Anybody have a tech sheet or S,M?
  17. Yesterday
  18. Hey Paulie, by any chance did you give it a shot? I’m having the same issue with two different fans.
  19. Manufacturer: Bosch Type of Appliance: Range Model Number: HGIP056UC/07 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): no Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes This mod# will not come up any where but the cust text me a pic and I feel sure it is right. Have not been out yet but apparently cust had a bacon fire and then E305. Thanks Boyd
  20. Manufacturer: Lg Type of Appliance: Wall oven Model Number: WDEP94230 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Y Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Y Looking for any tech data. Thanks
  21. Manufacturer: Samsung Type of Appliance: refrigerator Model Number: RF29DB970012 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Hi, Can you get the Samsung RF29DB970012 service manual? Thanks, Jim
  22. Hi repair techs and enthusiasts. I have a refrigerator questions. We invested a lot of$$, about $1000, in this fridge, now a week old, and love everything except the cooling itself. There are 5 "lower" temperature settings and three "upper" freezer levels for 15 setting combos in total. The strongest lower setting is for emergencies only, and is called PowerCold. It works great, but it cannot be used for long times, so the strongest to use has all 4 leds on. On that setting, it takes 12-24 hours to get back to spec temperatures once you go grocery shopping. (This is with the freezer on the coldest setting, diverting most cooling air from the warmer fridge.) Spec temps are, IMO, -9F freezer and 40F refrigerator. Also, there are visible water droplets in the ducting area of the the fridge air exchange section. And if dampness or standing water in the crisper drawers, it doesn't dry, even when the vents are 100% open. But, to be honest, at 40F the vapor pressure is going to be low so I don't know. There are droplets accumulating on the outside of the lower hinge of the freezer drawer. I'm guessing the installer messed up with the hinge swap. The design has the warmer, high-pressure-region (i.e., condenser) fins on the bottom. It's a great use of space and aesthetics. A fan mounted sideways in the rear bottom sucks cooling air in from the front, with some cardboard below the evaporator coils to help direct the air to move past the coils. During operation, these fins only get up to about 92.5 F in 74 F ambient air. I have another fridge I have to use for more robust cooling and it's coils are at 102 F, and mounted vertically, allowing more traditional convective cooling of them. The cooling seems very weak to me. Is it possible to upgrade the rear fan speed? Is there an easy way to test if the amount of refrigerant installed at the factory is correct? Should I get a different brand that cools better? If so, what brand? I'm constrained on a few things like width and bottom-mounted freezers are ruled out due to ice tray tilting mishaps when bending down.
  23. Uses this manual: The schematic in this bundle: The check routine request and error codes in this bundle:
  24. Uses this manual: And this parts list:
  25. Thermador T42BT120NS/02 Refrigerator Parts List View File Thermador T42BT120NS/02 Refrigerator Parts List Submitter Son of Samurai Submitted 07/02/2025 Category Appliance Repair Manual Pot Luck Supper
  26. Version 1.0.0
    0 downloads
  27. Son of Samurai
    Tech sheet
    Domo, Captain!
  28. KitchenAid KRFC300ESS07 Refrigerator Tech Sheet View File Pub Tech-Sheet-W11542405-Rev B Submitter Captain Dunsel Submitted 07/02/2025 Category Appliance Repair Manual Pot Luck Supper
