  2. Today
  3. Yesterday
  4. Will this one work?
  5. Also, I just realized that I mistyped the model number in the topic line and my first post. I transposed the D and T in the prefix. Sorry about that. The correct model number is : GDT630PYR3FS
  6. Adding to this saga: I replaced the pressure switch, and no improvement. I am not really surprised too much but figured it was worth a try. So in watching the overall behavior of the machine, I noted the following: When I first start a cycle, the first thing the machine does is run the drain for a short time, I presume to remove any standing water that was dumped in while loading. It seems to me that in the past, this initial drain cycle lasted 10 or maybe 20 seconds (that's a rough guess) before stopping and starting the fill step. What I see now it that drain step is very brief, maybe 2 or 3 seconds before it starts to fill. The way I would assume this works is that if there is water actuating the pressure switch, the control would start the drain pump until the switch opens, then run for some fixed time to get the last of the water out. I would think it would do the same at the end of the wash cycle. If the switch is already open, then it just runs through the fixed time. Anyone know if that's how this is supposed to work? Nothing else makes sense to me but I have been wrong before! If the pump out time is now much shorter than it should be for some reason, then I think this could be a controls issue. Is there a way to reset or otherwise access any control data? I have tried cutting the power to the machine and restarting as well as putting the control into diagnostic mode. It shows no errors and the power cut did not change anything. I do not have any technical data on this machine and can't seem to find any. Can anyone point me to a place to find a tech manual? Any thoughts on what I might be missing? I appreciate any input. Thanks.
  7. Manufacturer: Whirlpool Type of Appliance: Gas Cooktop Model Number: SCS3014LB0 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes
  8. Thanks
  9. Last week
  10. Manufacturer: Liebherr Type of Appliance: Refrigerator Model Number: bf1061 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): y Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): y Found out it is a 13F so apparently we don't have much of this German brand bummer. Appreciate the help...
  11. Patrick.j
    Lokring Kit Contents Comparison
    thank you guys, i am trying to find the most common sizes that should be put into my lokring kit. ever time i seem to try to do lock ring i don't have the correct sizes and end up using my torch
  12. Electrolux EW30DS Range How to change the Hidden Bake Element Video View File This is a video provided by Electrolux of how to access and replace the "upper" or "main" oven bake element in the EW30 Dual fuel Range with second oven drawer. Submitter LewsAppliance Submitted 04/17/2025 Category Appliance Repair Manual Pot Luck Supper
  13. LG LFXC22396S/05 Refrigerator Freezer door frost issues Service Bulletin View File PUB CNZ202000272-05 Applies to many models -- full list is at the end of the document itself Submitter Vance R Submitted 04/17/2025 Category Appliance Repair Manual Pot Luck Supper
  14. Seems to old to come up with the wiring diagram or anything on the Frigidaire site!
  15. Manufacturer: Frigidaire Type of Appliance: Refrigerator Model Number: FRT18DRCW Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Frigidaire FRT18DRCW0 refrigerator service manual request. Thank you
  16. Version 1.0.0
    5 downloads
  17. Richie Mac
    Dryer Service Manual
    Needed this, thanks Cap!
  18. Thanks, @THRAMICH! Approved.
  19. Whirlpool YWMH54521JZ Microwave Tech Sheet View File PUB W11297786 Rev B Submitter THRAMICH Submitted 04/17/2025 Category Appliance Repair Manual Pot Luck Supper
  20. Casualcamo
    Viking Range
    Im looking for this too
  21. Uses the same tech sheet as this model:
  22. Version 1.0.0
    1 download
  23. Samurai Appliance Repair Man
    True Kegerator TDD-4 tech sheet please
    Da nada, compadre.
  24. Thank you, @Captain Dunsel!!
  25. Captain Dunsel
    Nothing here!
  26. @jfirestone There are 2 ways on servicematters to find the tech sheet. 1. Is to get rid of the 665. part of the model number and use 4579N611 and search again. 2. Is once you found the parts list the tech sheet number is usually number 1. On the parts. W10880570 Tech Sheet, English
  27. Uses the same tech sheet as this model:
  28. I uploaded this for you, pending moderator approval.
  29. Version 1.0.0
    1 download
    PUB W11297786 Rev B
