Upcoming Events
26 April 2025 02:00 PM Until 03:00 PM
Where: Online via Zoom
- Today
Son of Samurai started following Service Manual needed FEF316BSF
Son of Samurai replied to drew 83's topic in Appliance Service Manual Requests Forum
Thanks, Cap! -
New Appliance Service Manual added: Frigidaire FEF316BSF Range Wiring Diagram
Frigidaire FEF316BSF Range Wiring Diagram View File Pub Wiring Diagram 316255306 Submitter Captain Dunsel Submitted 04/21/2025 Category Appliance Repair Manual Pot Luck Supper -
Captain Dunsel started following 110.28012011 Kenmore Washer Tech Sheet Needed
Captain Dunsel replied to David1's topic in Appliance Service Manual Requests Forum
Uses the same aa this model:- 1 reply
- 1
David1 started following 110.28012011 Kenmore Washer Tech Sheet Needed
David1 posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Kenmore Type of Appliance: TL Washer Model Number: 110.28012011 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes 110.28012011 Kenmore Washer Tech Sheet Needed please. -
Hotpoint Gas Range RGAS300DMWW making smell
ol_lonely replied to MelB's topic in DIY Appliance Repair Help
If you smelled them, they are in the air in your apt, and can be "burned" in with gas. For sure -
cowboyj16 started following Hallman UPN120FDMP Gas Range Parts Manual
cowboyj16 joined the community
Héctor19091987 joined the community
Bobwillbrb joined the community
Captain Dunsel started following Frigidaire FEF316BSF Range Wiring Diagram
Uploading wiring diagram and waiting on approval: -
Manufacturer: Frigidaire Type of Appliance: Electric Range Model Number: FEF316BSF Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Service Manual needed FEF316BSF
Service Manual Request WED4800XQ1
Uses the same one as this model:- 1 reply
- 1
Manufacturer: Whirlpool Type of Appliance: Dryer Model Number: WED4800XQ1 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Service manual needed WED4800XQ1
Kenmore / LG Service Manual
Captain Dunsel replied to Joe B, Stoughton Appliance Repair's topic in Appliance Service Manual Requests Forum
See if this works:- 1 reply
- 1
Joe B, Stoughton Appliance Repair posted a topic in Appliance Service Manual Requests Forum
Manufacturer: LG Type of Appliance: Refrigerator Model Number: 795.77242601 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Hello, Looking for a service manual. Customer complaint: no ice, no water. Customer has already tried changing water filter. Saw old posts about possibly crossing to an LFD21860* or LFD25860* , but other than a service bulletin for melted light bulb housing only found dead links and PMs for those service manuals. Are these manuals still available? Thanks, joe -
Whirlpool Dryer Tech Sheet Please
Captain Dunsel replied to Andy's Appliance's topic in Appliance Service Manual Requests Forum
Uses the same as this model:- 1 reply
- 1
Andy's Appliance posted a topic in Appliance Service Manual Requests Forum
Manufacturer: WP Type of Appliance: Dryer Model Number: 110.68532700 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Thank you!! -
GE dishwasher GTD630PYR3FS draining but not completely
dp310ce replied to clavius's topic in DIY Appliance Repair Help
Remove the drain hose at the pump clamp on a separate drain hose on run up to the sink run it through a drain cycle if it still not drain properly replace the pump -
Rameshsharma joined the community
armanDuanbekov joined the community
mra.swflorida changed their profile photo
- Yesterday
LG Compactor joined the community
Timruddell joined the community
itzon joined the community
Javier777 joined the community
SAWbone joined the community
FULL Service Manual Needed
vee8power replied to CGA's topic in Appliance Service Manual Requests Forum
Will this one work?- 1 reply
- 1
clavius replied to clavius's topic in DIY Appliance Repair Help
Also, I just realized that I mistyped the model number in the topic line and my first post. I transposed the D and T in the prefix. Sorry about that. The correct model number is : GDT630PYR3FS -
Adding to this saga: I replaced the pressure switch, and no improvement. I am not really surprised too much but figured it was worth a try. So in watching the overall behavior of the machine, I noted the following: When I first start a cycle, the first thing the machine does is run the drain for a short time, I presume to remove any standing water that was dumped in while loading. It seems to me that in the past, this initial drain cycle lasted 10 or maybe 20 seconds (that's a rough guess) before stopping and starting the fill step. What I see now it that drain step is very brief, maybe 2 or 3 seconds before it starts to fill. The way I would assume this works is that if there is water actuating the pressure switch, the control would start the drain pump until the switch opens, then run for some fixed time to get the last of the water out. I would think it would do the same at the end of the wash cycle. If the switch is already open, then it just runs through the fixed time. Anyone know if that's how this is supposed to work? Nothing else makes sense to me but I have been wrong before! If the pump out time is now much shorter than it should be for some reason, then I think this could be a controls issue. Is there a way to reset or otherwise access any control data? I have tried cutting the power to the machine and restarting as well as putting the control into diagnostic mode. It shows no errors and the power cut did not change anything. I do not have any technical data on this machine and can't seem to find any. Can anyone point me to a place to find a tech manual? Any thoughts on what I might be missing? I appreciate any input. Thanks. -
Manufacturer: Whirlpool Type of Appliance: Gas Cooktop Model Number: SCS3014LB0 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes
Whirlpool WFW70HEBW1 Washer Tech Sheet
fcm350 commented on Son of Samurai's file in Appliance Repair Manual Pot Luck Supper
- Last week
Liebherr bf1061 counter depth refrigerator manual if possible please
dfphoto posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Liebherr Type of Appliance: Refrigerator Model Number: bf1061 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): y Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): y Found out it is a 13F so apparently we don't have much of this German brand bummer. Appreciate the help... -
Lokring Kit Contents Comparison
Patrick.j commented on Son of Samurai's file in Appliance Repair Manual Pot Luck Supper
Electrolux EW30DS Range How to change the Hidden Bake Element Video View File This is a video provided by Electrolux of how to access and replace the "upper" or "main" oven bake element in the EW30 Dual fuel Range with second oven drawer. Submitter LewsAppliance Submitted 04/17/2025 Category Appliance Repair Manual Pot Luck Supper
LG LFXC22396S/05 Refrigerator Freezer door frost issues Service Bulletin View File PUB CNZ202000272-05 Applies to many models -- full list is at the end of the document itself Submitter Vance R Submitted 04/17/2025 Category Appliance Repair Manual Pot Luck Supper
Frigidaire FRT18DRCW0 refrigerator service manual request
Seems to old to come up with the wiring diagram or anything on the Frigidaire site!- 1 reply
- 1
Blog Entries
By Son of Samurai in Appliance Repair Tech Tips2 comments
By Son of Samurai in Appliance Repair Tech Tips4 comments
5 comments
Topics
Captain Dunsel · Started
