  1. Today
  2. @DarkHorse96 Don't try it - you will never get them back together correctly. After you get the new one mounted by making a mounting bracket like I suggested and you know all is working OK - then try to take the old t-stat apart and see what you end up with.
  3. I know I’m late to this party, but just late night scrolling and came across this topic and wow! Has a service bulletin been released about this? Our local supplier here says the boards for these is the number two selling part in their warehouse, I’ve replaced two boards in the last two weeks on two different machines, now the gears are turning in my head because they were only four year old machines with very strange behavior. Haven’t heard back from either customer, only time will tell…
  4. Yesterday
  5. Captain Dunsel
    FGHD2465NF1A tech sheet
    @fcm350 Tech sheet is also in the same download as the parts list!
  6. Captain Dunsel
  7. Manufacturer: Fridgadare Type of Appliance: Dishwasher Model Number: FGHD2465NF1A Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Looking for tech manual to put the dishwasher in diagnostic mode. I found one on the parts but not how to put it into diagnostic mode. Customer said the error code was ER. Thanks for your help.
  8. fcm350
    Service manual
    Thank you.
  9. Asko
  10. Captain Dunsel
    Frigidiare Ref mod: FGUS2642LF2
    Try this also:
  11. Captain Dunsel
    This doesn't come up for your model but try this.Frigidaire is horrible for service manual.
  12. Techonamission
    can you provide the Service manual too please? This tech sheet doesnt have error codes
  13. Captain Dunsel
  14. Manufacturer: Frigidaire Type of Appliance: Refrigerator Model Number: FGUS2642LF2 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Requesting tech sheet for Frigidiaire ref mod: FGUS2642LF2
  15. Good question how does it come apart?
  16. Thanks! That sounds like a viable alternative if I can't figure out how to use the actual mount off the original 10085. I did notice that there seems to be some kind of bend-over / crimp tag on the bottom 2 corners of both the original thermostat and the substitute. Has anyone tried to bend those tabs of a dead one to verify whether we could theoretically release both stats' mounts and securely attach the original mount to the 10085? Of course, I'd also be betting that the 10085's exterior mount will pull off an unseen underlying shaft because that big threaded region its shaft may be too long to fit under the old mount.
  17. Manufacturer: Asko Type of Appliance: Dryer Model Number: T411VDWU Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Looking for service manual, thanks! T411VDWU
  18. Thanks Vance! You’re the man!
  19. Son of Samurai
    Thanks, Vance! Approved.
  20. LG WT8480CL Washer Service Manual View File PUB MFL69647043 Submitter Vance R Submitted 06/08/2025 Category Appliance Repair Manual Pot Luck Supper
  21. Thanks, Vance! Approved.
  22. LG WM6998HBA Washer Dryer Combo Service Manual View File PUB MFL71873719 Submitter Vance R Submitted 06/08/2025 Category Appliance Repair Manual Pot Luck Supper
  23. Captain Dunsel
    Service manual
  24. Wouldn't be hard to make a mount - just use a strip of plumbers strapping cut to the correct length, make "L" bends at each end so enough of the knob shaft will stick through the mounting hole, find a nut the correct size of the center threaded mount. Drill small enough holes for the two mounting bolts/screws will thread into the plumbers strap or use speed clip nuts if the holes that are in the plumbers strapping is too big and already at the correct mounting screw spacing.
  25. Captain Dunsel
    @JSMequipmentservices I wonder if this one is close enough?
