Maytag Atlantis Washer Motor Pivot Plate
Sluggish spin and/or agitate in this washer? One of the first things to check is the pivot plate. If it's sticking, the motor mounting spring won't put enough tension on the belt and it'll slip on the pulleys (and burn up the belts) instead of doing the bidness of working that agitator and inner basket!
Washer Repair
· 68 images
  • 68 images
  • 17 image comments
