Kentucky Fried Control Board on a Frigidaire FEF352AWF Range: Inside View
And it's nuked! This failure took out several traces on the board. Amazingly, the clock was still working but neither bake nor broil worked because the line relay was fried.
This range was throwing an F1 error code. F1 on a Frigidaire ranges means a bad control board. Sometimes, it's just a burnt solder joint and can be repaired.
Buy the replacement control board here with a one year warranty: http://www.repairclinic.com/PartDetail/Oven-Control-Board/316207511/1036364
Ovens, Ranges, Stoves
· 58 images
  • 58 images
  • Taken with Apple iPhone 4S
  • Focal Length 4.3 mm
  • f Aperture f/2.4
  • ISO Speed 125
ahhh... the exploded view ...
Scottthewolf
Do you want mashed potatoes with gravy and cole slaw with that?
J5*
what caused it ?
a short to earth element ?
or just crapped itself ?
