playfullyvivid
I have an LG WT7300CW 01 washing machine. At one point it began to turn on only when it wanted, and recently outright stopped turning on. I took it apart to take a look and deduced that when the front touch panel is attached, the thing would lock up and no longer work.
I figured the issue was the panel went bad so I ordered a used replacement from eBay. Hooking that one up did not solve the problem, and I’m no longer sure what the issue is. I would think the board is the issue, but when I interface with the board without the touch panel, everything works fine.
https://imgur.com/a/St0DuBY
I took a video showing the issue. In the video, the touch panel is installed and the dial will not work. I quickly uninstall the panel and try to rotate the dial again, but now it works.
This suggests that attaching the touch panel breaks the circuit. I could see that being the issue with the old one, but then why is this also happening with the replacement. Maybe the seller sold me a bad one I suppose, but I wouldn’t know how to test that. Right now we’re using it without the touch panel but ideally would want it fully assembled again.
  • dfphoto
  • playfullyvivid
Posted Images
seems like something is touching the between the board and the UI
Maybe these two videos are the answer. I really don't know.
In the video with the guy in the black shirt there is a link that skips to the actual fix.
Hopefully that works
good idea something is touch look  at the assembly carefully
