colonelsanders
Hello everyone.  I am trying to fix error code F7 for a GE oven range, but I cant figure out how to get the control panel off this thing.
There are 7 bolts under the panel which I tried taking off, but the panel is still firmly in place.  From the look of things I may need to remove the entire top part of the range and burners, which have screws that are very likely rusted through and will need drilling.  Before I get into that I was hoping someone here might know an easier solution.  I was unable to find any resources online on how to take off this front panel.
Any help would be much appreciated.
This is the panel 0029449321_6.gif and this is the range Dispatcher?RequestType=Image&Name=035372
Take the burner knobs off.  Under them you will see a large plastic nut holding down the user interface.  Taking care disconnect the ribbon connection. Set aside the UI.  Remove screws that are reviled by removing UI.
  • Like 3
colonelsanders
Oh man thank you so much! You saved me tons of time.
