Whirlpool GHW9100LW1 Beeps & sometimes won't select chosen cycle
GreenGrasshopper
I have an eleven year old duet ghw9100lw1 washer (it's always been mine) and it's acting oddly in two ways:
1. It will beep during some cycles, but no error code comes up; it will finish the cycle just fine.  Should I worry?
2. I will try to select a cycle, and it will select a different cycle.  If I put it on normal for instance, the light and settings for delicate will come up.  It won't then allow me to select normal until a load has run.  I have tried searching for an answer, but can't find one.  How can I fix this?
Thank you
  • GreenGrasshopper
  • Thirstytech
Do you have issues with any of the other functions on the panel? Sounds like the user interface would be the culprit.
Part number: AP3129636
GreenGrasshopper
Thank you for your reply.  :)
No, that's the only thing it does, but it is an annoying thing!
