fuzzielogicworks
Hello gentlemen have a whirlpool dryer model number WED5700VW0 works & dries fine & time dry feature advances fine. Dryer will not move or advance on the Auto cycle. As I understand it (some research) the timer motor should run in the Automatic cycle anytime the heating elements cycle off & stops the heating. Checked the heating elements & they do cycle off & on however the timer never moves in Auto. The dryer advances & works perfectly in the time dry cycle. So I've mistakenly replaced the timer & the moisture sensor circuit board & the problem still exists! Ran the dryer with no clothes so no moisture in the dryer & it still never moves would this eliminate the moisture sensor? Please help guys I'm at my wits end with this issue! I've been told to just use it on the time dry cycle but now I'm far to invested now. Any help would be greatly appreciated!!!
Most likely the thermostat on the heating element if it has a small orange wire going to it
fuzzielogicworks
Is that thermostat just a safety thermostat? Thought if this thermostat was bad the dryer would just not heat. The orange wire you mentioned is that part of the Auto cycle? So sorry I'm not questioning your expertise just trying to understand what is going on. I looked but could not find a wiring or tech sheet so really lost here. Thank You!!
no worrys , if it has a orange wire , it goes from the timer to the thermostat and supplies current to the timer motor when the element is off
Does it have that orange wire?
If it had a moisture sensor it doesn't use the thermostat to advance the timer, check the wire running from the moisture sensor to the circuit board for continuity to ground, if there is look for a pinched wire or something shifting the sensor bars together
fuzzielogicworks
Going to have to make some time to take it apart again. For some reason I never looked at the moisture sensor inside the tub. You think maybe they got damaged somehow? I did notice a yellow wire w I think a red stripe going behind the blower housing in the back. Is this the wire you would like me to check? This dryer has a small moisture control board mounted in the control panel area on the right side when looking at it from the front. I did replace the timer & the small electronic board lets call it the MCB & the result was the same. I will check the moisture sensor inside the drum & the wire that goes from it to the MCB. THANKS to everyone for the help I'll report back what I find ASAP.
