Hello,
I have a Kenmore refrigerator 596.72913200 which has the warmer compartment too cold.
The control has been set to the lowest (warmest) setting, "1", but items in the fridge area are freezing.   I have not taken apart, and hope to find some guides of how to fix.  I cannot move the fridge from where it sits (long story), so I am hoping to address the problem by checking replacing the thermostat in the warmer compartment.
For now let's assume the condensor coils are clean -- I am getting good cooling in the freezer.
Looks like the "thermostat" is simply a door that closes off the cool air from the freezer (where the evaporator is).   Could the problem be this door or the associated belt damper, or the damper control assembly?
Thanks in advance
Jake The Repairman
  • jakeo25
  • johntech
  • 16345Ed
First thing to check is weather the damper door is closing. You can normally test this by adjusting the thermostat for the refrigerator compartment up and down while you hold the door switch and observing. Holding your hand in front of the vent to make sure air is not blowing when closed. If you hear the motor but air still flow in then you need a damper. Part number: WP67003410
Door breaking off damper is a pretty common failure.
Yes, johntech, that was the information I needed.  Thank you.  Best site on the web for quick answers, I might add.
Fairly easy to address the problem.  Even though warmer compartment was about 30°F (yes!) and thermostat set to warmest setting "1", I could feel a steady flow of air.  Disassembling I found some ice build up around the white plunger that opens/closes the damper door (just to left of spring in photo above).  After melting and drying it still would not fully close. (I held the unit's coils and box next to the freezing air and watched the damper move).
New part on order.
I also noticed my tenant was keeping the freezer at the coldest setting, and while this normally shouldn't be a problem, a short term fix would be to back off the freezer setting until I replace the damper in the warmer compartment.
This could be why damper froze up.
Both settings should be at mid range.
You want 0 degrees in freezer and 37 or 38 in fresh food section.
