New Appliance Service Manual added: GE 27 inch Top Load Washer Service Bulletin - Tub Pressure Chamber
View File
Models affected:
HTW200 GTW485 MTW200 GTW490 GTW220 GTW680 HTW240 GTW685 GTW330 GTW750 GTW460 GTW755
Tub Pressure Chamber Port Flash
The following symptoms may be associated with tub pressure chamber port flash.
No spin, no agitate, stops or pauses mid cycle, no drain or does not drain all the way, clothes too wet at end of cycle, started pumping on its own, drain pump clearing, drain pump runs/noise constantly with no water in the tub, excessive running pump and water drains, but basket doesn’t spin.
PUB HL01-17
  • evaappliance
can i get the tech manual for a gtw460asjoww . just able to find this service pointer. thank you !
i'm sorry , i found it !!   thank you  !!!
