My teenager decided to do 2 loads of laundry in one load and now my agitator won't work.
The agitator dogs were bad and I replaced those but it still won't agitate.
Everything else works fine.  It still fills, spins and drains great.
I've pulled the motor coupling and it looks a little worn but not fubar (I'll replace it now that I've got it apart.)
Is there anything else I should be looking for before I replace the gearcase? and is there anyway to know if the gearcase is bad before I fork over the big bucks on a 30 year old machine?
thanks!
  • Replies 1
  • evaappliance
  • FRS56
Unless your agitator base is stripped out ( rarely the case ) you will have a bad transmission if the motor is running
