Hi all, and Happy New Year.
Our front loading washing machine (per title) was operating normally today.  At one point in the wash cycle, my wife hit the pause button, to add an item.
The door unlocked and allowed her to do so, but since closing it, has made an unpleasant buzzing sound in all cycles.  My research so far is most consistent with a pump issue, but my hesitation with that diagnosis is
1- The sound is present during fill and spin actions.  I would think a pump issue to make noise when water is being pumped out only.
2- It wasn't there before the pause and add action, and appeared immediately afterwards.  I don't know what would cause that sound to start as a result of that, but the timing seems odd.
I'm hoping some forum members might have a guess what to look at.
  • Replies 6
  • Steve Y
  • AccApp
  • darren412
It sounds like a door lock issue to me. Does the noise change when you apply pressure to the door at the lock area?
yes ,that sounds like a door lock issue. I have run into that buzzing issue a few times with the Frigidaire door locks.  Changing that lock should take care of the buzzing problem.
@AccApp Yes- applying pressure to the door at the lock changes it from BUZZZZZZZZ when not touched to buzzzzzzzz when pressed.  Pressing also induces PAU on the display, and the countdown timer resets.  If I let it do it's thing, it appears to launder clothes as expected, but unacceptably loud.
Is this a common failure scenario for a door lock- no build up, just suddenly buzzing out of the blue?
And when looking up the part, I see this "door lock/switch assembly"- is this the part you'd be replacing?  https://www.repairclinic.com/PartDetail/Door-Switch/131763256/4547033?modelNumber=ATF6700FS1
Yes that is what you will be replacing . Make sure that the lock latch screwed onto the door itself is not broken either. Some times a piece of that will break off into the lock also.
Yup, sounds like a textbook Frigidaire F/L door lock failure.
OK, I'm sold: part ordered.
I had to replace the latch previously. Easiest appliance fix ever.
Thanks all!
