Can anyone help with WFW92HEFW washer? it turns on but constantly have the "---" code on the display and won't start! i tried to turn the knob but it still doesn't work.
I already replaced the panel, it had a "E03 F06" error before.
really appreciate it!
  • Lighthouse
  • 16345Ed
  • bgoat
The code is for a communication error between the user interface & the main board. if you remove the top you should see tech sheet inside the cabinet. on page 9 you will find the error code that says:
Communication between Appliance Control Unit (ACU) and User Interface (UI) has not been detected.
Possible Causes
• Verify continuity in cable between ACU (J19) and UI (C2). See wiring diagram on page 22.
• Check AC and DC supplies. See TEST #1 (ACU Power Check) on page 13.
• See TEST #2 (User Interface) on page 14.
agree with Lighthouse...
And triple check your connections.
