Hello.
We have a LG front loading machine that is moving around during the spin cycle.  Bearings and spider appear to be in good shape.  Is the next thing to check/replace the shocks?
Thanks.
  • Replies 9
  • john63
    4
  • CDS
    4
  • J5*
  • johntech
A few questions...some of which may seem odd...
Is the washer on a wood floor?
Has the washer been relocated recently...moved into new home...or...you've moved into a new home and the washer came with sale of the home?
Any error message displayed?
No, it's it the same spot it has been in for over a decade, on vinyl flooring.  No error message, it just moves askew.
How full are you filling the tub with laundry?
The last one wasn’t too big.  A couple of towels and some clothes.  Not even half full.
With an empty tub...
Power on
*do not select a cycle*
Select highest Spin Speed
Press Start
When control panel displays 7 minutes remaining...does the washer tub shake excessively (even though empty)?
If yes...failed Inner Tub (cracked/bent).
If not then suspension shockies
It's a small possibility.
These washers pre-date the True Balance feature...now in use.
WM0642 models are roughly 10 years old.
It would be far more likely that the tub support/trunnion has a crack or is disintegrating...causing severe imbalance during the high speed spin cycle.
Another clue would be...burning rubber odor and door gasket "fuzz" (fine rubber specks) on the gasket and/or clothing.
I tried the method listed above.  I took a video of it, but I can't figure out how to upload it.  I didn't notice any terrible vibration at the 7 minute mark.
You can try installing rubber pads...made by LG (4620ER4002B).
Designed for smooth floor surfaces...to stop the washer from sliding.
Order 2...install on front leveling legs.
