New Appliance Service Manual added: GE 2012 Dryer Customer Care Training Presentation
View File
Models:
GTDP740EDWW/GDWW GTDL740EDWW/GDWW GTDS810EDWS/GDWS GTDS815EDMC/GDMC GTDS820EDWS/GDWS GTDS825EDMC/GDMC GHDS830EDWS/GDWS GHDS835EDMC/GDMC GTDS850EDWS/GDWS GTDS855EDMC/GDMC GTDS860EDWS/GDWS GTDS865EDMC/GDMC
14 .......................................................................Schematic, Electric Dryer - AC Voltage Into The Board and Motor Switch
15 .......................................................................Schematic Gas Dryer - AC Voltage To The Board
16 .......................................................................Schematic, Electric And Gas – Long Vent
17 .......................................................................Schematic, Electric And Gas – Mist Water Valve18, 19, 20, 21 ..................................................Service Mode
22, 23 ,24 .........................................................Resistance/Voltage Charts
25 .......................................................................Main Board Connecter Locations
26 .......................................................................Diagnostics From The Board - Sensor Rods
27 .......................................................................Diagnostics From The Board - LED Light
28 .......................................................................Diagnostics From The Board - Inlet Thermistor
29 .......................................................................Diagnostics From The Board - Outlet Thermistor
30 .......................................................................Diagnostics From The Board - Heaters Resistance Reading31 .......................................................................Diagnostics From The Board - Heaters Voltage Reading / Low Heat or No Heat Issues
32 ...................................................................... Diagnostics From The Board – Dead Board
33 ...................................................................... Diagnostics From The Board – Water Valve
34 ...................................................................... Diagnostics From The Board – Gas Valve
35 ...................................................................... Diagnostics From The Board – Motor Resistance 36 ...................................................................... Igniter And Flame Viewing
37 ...................................................................... Installation
38 ...................................................................... Installation – Cord Replacement
39 ...................................................................... Installation – Vent Exhaust Length40, 41, 42 ........................................................ Installation - Location
43 ...................................................................... Installation – Leveling and Stabilizing 44 - 52 ............................................................. Reversing the Door Swing
53 - 58 ............................................................. Controls
59 ...................................................................... Dryer Features
60 ...................................................................... Dryer Features – Clean Speak
61 ...................................................................... Disassembly
62, 63, 64 ........................................................ Disassembly – Backsplash Removal65, 66 ............................................................... Disassembly – Top Cover Removal67, 68 ............................................................... Disassembly – Front panel removal69, 70 ............................................................... Disassembly – Drum removal
71 ...................................................................... Disassembly – Internal Components – Electric
72 ...................................................................... Disassembly – Internal Components Electric - Thermistor/ Thermostat Locations
73 ...................................................................... Disassembly – Internal Components Gas
74 ...................................................................... Disassembly – Internal Components Gas - Thermistor/ Thermostat Locations
75 ...................................................................... Rear Roller Support Bulkhead - Removal
76 ...................................................................... Blower
77 ...................................................................... Heater Removal – Electric
78 ...................................................................... Heater Removal – Gas
79 ...................................................................... Heater Removal – Gas Valve Assembly
80 ...................................................................... Heater Removal – Main Burner Assembly
81, 82 ............................................................... Heater Removal – Glow Bar Replacement
83 ..................................................................... Flame sensor - Removal
84, 85 ............................................................... Water Valve
86 - 90 ............................................................. Before You Call For Service
  • Replies 0
