If someone could please help me, It would be greatly appreciated. I have a Kenmore 700 series dryer, mod#110,68102310. The dryer turns on and runs for about two minutes then shuts off with error code F3 E2. The thermister and fuse both are new due to neither one having continuity when checked so i replaced them both. Here is where it gets good, the heating element is not coming on. I checked continuity on it and havew about 12.3 ohms. Also i have 120v on BOTH pins. I put my meter ground to the casing and checked each while on. 120 on each...240 on both. HOW CAN THIS BE? I am seriously about to take my frustrations out on this thing. I read that the F3E2 was for the moisture sensor, so i checked it. No short found. No continuity.Someone PLEASE help .
   Thank you in advance,
   C.J.
  • evaappliance
  • Ian B
  • CJ1
  • MrApplianceMechanicsburg
Is the dryer vent clogged? Just because the thermistor isn’t shorted doesn’t mean it isn’t bad. That error is a faulty thermistor. Make sure the dryer vent isn’t clogged.
On 11/13/2019 at 7:41 AM, CJ1 said:
240 on both.
If your getting 240 at the element and it’s not coming on, it’s bad
  • 1 year later...
Anyone have tech sheet or manual
