I have a Kenmore 790.71513400 gas range that the oven will not light. When this started I assumed it was the igniter again, I had replaced it approximately three years ago. You could hear the relay snap after setting the oven temperature on the panel, but the igniter would not glow. I replaced the igniter, but it still does not glow/light. Again, you hear the relay snap, but that is it. I took apart the igniter wiring to check for bad connections or corrosion, and the smaller spade terminal on the gas safety valve didn't look too good. All of that is cleaned up now. I have not checked for voltage, would that be my net step?
  • Replies 1
  • john63
  • mzr
Yes.
Check for 120 volts to igniter...when oven has been turned on.
If no voltage...failed Electronic Oven Control.
