I need help diagnosing my washer. The problem arises when the washer is going through its normal cycle and then later stops mid-cycle to show the IE error code. It's a head scratcher because I've tried almost everything I know to be associated with the IE error code. So far I've,
-Checked all the hoses (water & drain) for any kinks, leaks, or blockage and debris. [All Clear]
-Checked and cleaned the mesh filters for the water intake. [All Clear with the exception of very light mineral deposits]
-Checked the water valves, hoses, and pressure were open and flowing normally. [All Clear]
-Checked and cleaned the drain hose including its positioning to prevent siphoning. [All Clear]
I keep reading through the manual too but I'm at a complete loss.
https://www.searspartsdirect.com/model/2gpz2eaxe3-000583/kenmore-elite-79631523211-washer-parts
Any ideas?
Thanks to anyone who can help.
  • Replies 4
  • Vance R
  • Appliance100
  • Grey
IE looks to be a water fill issue.
How did you check all the valves and flow? test mode?
  • 1 year later...
Going to a client house thursday to service a Kenmore washer with error code as same LE. Upon start up. No movement of drum. I will give updates later.
The author of the thread had an ie errror which is for inlet error. Your error is for a locked motor error. Please get the model number and start a new topic for help in troubleshooting
Ok and thanks for reaching out.
