blockychief89
I have an Admiral ATW4475VQ1 top loading washing machine that tries to shake itself apart every time it's in the spin cycle.
I've already done a few things to find/fix the issue, but it's still not much better.
The things I've tried:
1)making sure the washer is level
2) making sure  the laundry  load is balanced
3) replacing the 3 suspension springs
4)checking the pads under the drum
The machine is level, loads are balanced, and the pads look fine.
Replacing the springs helped a little, in that the drum doesn't bang against the sides much anymore, but the whole machine shakes worse than it did. It'll try and walk itself out of its closet if I don't sit on it.
I'm not a professional, so I'm not sure what to look for next. Any insight, tutorial links, etc. would be greatly appreciated by me and probably my downstairs neighbors.
Cheers!
  • blockychief89
  • Budget Appliance Repair
  • Blaiser
Is the rear motor counterbalance spring still attached and not rusted off at bottom frame mounting hole or mounting hole in frame rusted and a slot worn up to top edge of hole.
How did you check the three skate plate pads - if they are worn off to a flat thin state they need to be replaced
blockychief89
No exactly sure what spring that would be, but every spring and mount/bracket look to be in great shape.
To check the pads I opened up the machine and tilted the drum while I stuck my phone camera underneath to check it out. They all look healthy with a long ways to go before replacing.
I have also since checked the balance ring on top of the drum and it seems just fine
I can also provide pictures and videos of just about anything if needed.
1st Question:
Did you take tub off the base?  Skid Plate might have been installed upside down?
Check all (4) Springs - Three Springs around the tub and 1 Spring attached to back of machine to the base frame (LONG SPRING).
Is the Balance Ring in tact (present) under the top Ring Assembly?
Is the Agitator Block with Nut Tight (under the agitator)?
Did you replace the 3 Skid pads mounting on the frame and between the Skid Plate
You should be able to take the front cabinet off and bypass the lid switch to run the machine and take a video while it's shaking and possible show up all (4) Springs attached correctly!
