Frigidaire FEE368CCSD Range display blanks out
This started about 2 weeks ago that when the oven is turned on the Electronic Oven Controler goes blank that show the oven functions. The oven does not heat up in any mode. I can redo the inputs several times with the same results. Has the EOC failed or do i need to look at other parts of the unit?
Source: Frigidaire FEE368CCSD Range display blanks out
This is a bad electronic control, slam dunk. Come git you one...
Create a custom theme
