    3,454,776
Hunting down a mystery leak in an LG steam dryer
<<<DLEX7177RM Steam dryer has mystery leak that the customer notices after most cycles, coming from near the front center of the machine. I ran this unit for quite some time and could find no leak.>>>
In most cases---this is caused by a partially restricted vent system.
When the back pressure increases due to a restricted/partially blocked vent system---moisture/steam "escapes" from the drum during the cycle (fairly common).
Check all hoses for tight connections as well (it's rare to find a leaky hose).
<<<I could not locate the source of the leak. I went into dx mode and activated the steam generator, and only ended up with a drum full of water>>>
To initiate the DIAGNOSTICS TEST MODE...
Press/hold the MORE TIME and LESS TIME buttons
Then press the POWER button and release all three buttons.
To test the STEAM GENERATOR funtion...
Press the START/PAUSE button 4 times.
NOTE: During the STEAM GENERATOR test mode---the SG pump *will flood* the dryer if allowed to run too long.
<<<Customer indicated that a previous servicer replaced something (maybe steam generator?) and indicated that this part breaks all the time and they should get used to replacing it.>>>
False.
ADDITIONAL NOTES:
The STEAM GENERATOR in an LG dryer serves 2 functions...
1) Static Reduction---Most of the dry cycles will add a small spray of steam into the drum during *the last* 15 minutes of a cycle.
2)The EASY IRON cycle adds a *heavy* amount of steam to the laundry load to leave clothes very damp in preparation for *ironing*.
If STEAM DRY is selected (any cycle)---the STEAM GENERATOR will be turned off during the last 8 minutes of the cycle.
If using the STEAM FRESH option---the SG will NOT energize if the Moisture Sensor Bars detect moisure in the load (clothing).
Source: LG Steam Dryer mystery leak - DLEX7177RM
