    861
    1,408
    3,311,283
Gas range goes BOOM! after a particular stove burner is lit
In this adventure into appliance dysfunction, the customer called me with a scary problem with her gas range. After she would fire up the left-front (LF) cooktop burner and it was on for less than a minute, a big flash-boom would erupt from underneath the burners. I reproduced the problem when I was there and it was a pretty impressive explosion! I wish I had gotten video of it but thought better of repeating it.
I knew I was dealing with a gas leak and had to get to the burner gas supply tubes to leak check them. I disassembled the range cooktop so I could get a look underneath the burners. Turns out this leak didn't even need gas bubble leak-check solution to find (click the pics for larger view):
That's the aluminum gas supply tubing for the LF burner. With a break like that, it's amazing that it was sending any gas at all to the burner. It was still supplying the burner with gas albeit at a reduced rate so the flames were more yellow than the other burners. The rest of the gas was flooding the compartment underneath the burners until it reached the Lower Explosive Limit (LEL) concentration for propane (which is 2.1% by volume, in case you were curious). Then the propane was in high enough concentration that it ignited from the open flame on the burner.
Range go BOOM!
Pants go brown.
So the next question is: How did this happen? Metal tubing that's not pressurized does not just spontaneously rupture.
Turns out the customer had been releasing the cooktop clips and lifting the top panel of the range without first unscrewing the burners. She would do this periodically to clean out the copious amounts of mouse poopy:
Every time she did this, however, she was flexing all the gas burner supply tubes which finally induced fatigue failure in the tube for the LF burner.
Why was the LF burner tube the first (and only, so far) to fail? Because it is the shortest tube. The other tubes, being longer, had more flex and were more forgiving.
So where are these mysterious burner screws that have to be removed? In this particular range (older GE), each burner has three mounting screws that need to be removed to release the burner base from the bottom of the cooktop panel. This way the tubing is not flexed when the cooktop is raised for cleaning or service.
What invariably happens with this design is that the mounting screws for the most-used burner (usually the RF burner for right-handed people) get rusted out like this:
Then either the head breaks off when you try to remove them or the head simply rounds out when you try to unscrew them. It's common to have to drill the screws out when this happens, which you can see in the photo above.
Moral of the story: Don't go messing with your appliances unless you know what you don't know! Just because you can undo some clips and take something apart doesn't mean you should, because there could be consequences that aren't even on your radar screen. Use the forums at The Appliantology Academy to get advice from the experts before you start mucking about with your appliances!
When dealing with gas appliances, don't assume anything: know what you don't know.
6 Comments
telefunkenu47
AMEN brother! Went on an LG F/L washer with a supposed bad pump yesterday laying on its back with the baseplate completely removed and the pump completely disassembled! I just walked away.didnt even ask for the trip charge. I'm just too old and irritable for this crap The Obama bumper sticker cinched the deal.
Link to comment
Yes---seen that as well:)
I've always felt that it was foolish to use "clips" on gas ranges.
Gives consumers the wrong impression---that the top cover of the range can be lifted for cleaning purposes.
Link to comment
I'm sure all that mouse poop enhances the flavor.
No, that's more decorative than anything, it's the urine that adds favor.
Link to comment
For gas ovens, I'm not a believer in electronics at all. Give me pilots, thermocouple valves, flametubes, etc. and parts that drop into their own little notches. Had an apartment building for a while, cleaning and inspecting those parts took all of 5 minutes between tenants and went well with cleaning the drip pans/defrosting freezer, etc. Look after them a bit and they will run well forever.
Link to comment
