  2. Only see that tech sheet for this one.Frigidaire is horrible for making service manual.Uses the same tech sheet as this model and that Tech Tip:
  3. Manufacturer: Frigidaire Type of Appliance: Oven Model Number: Cgih3047vfd Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Frigidaire Cgih3047vfd induction oven service manual request Thank you
  4. Today
  5. Yesterday
  6. fcm350
    Tech sheet
    I tried to put the fridge into the diagnostic mode and it just kept beeping. Even when I pushed the button to shut it off it still kept beeping, do you think since it wouldn't go into diagnostic that it might be a bad board. Thanks
  7. I tried to put the fridge into the diagnostic mode and it just kept beeping. Even when I pushed the button to shut it off it still kept beeping, do you think since it wouldn't go into diagnostic that it might be a bad board. Thanks
  8. Robert Couchman
    Bosch B21CL81SNS/04 Freezer DEFROST
    LolSo here's an update, I was able to do some research and cool the bi-metal to about 0° still measures open circuit. I ordered a replacement. In what may have been naive attempt to keep the fridge section and the food in it. Cool. I replaced the freezer drawers and plugged the unit back in. I had the steel cover off of the back side which covers the control board and another board, when I plugged it in there was some arcing in this secondary board. I immediately unplugged it. I don't see any burn traces or obviously damaged components but now I am really fluxed. Appreciate any help you can provide.
  9. Fixer
    AC Compressor making noise
    Opps, the audio file is not working so let me try that again. I attached it here. Also, as seen on the label the compressor unit is Carrier 24ABR360A360. AC Sound.mp4
  10. My outdoor compressor unit is making a buzzing sound. It appears to be cooling okay though it is an old R22 unit. I attached a recording made about 3 feet from the unit so you can hear it. I'm also attaching a photo of the unit itself and the label on the back. I'm new to the house so I don't know what it sounded like when it was new or what the history is on the unit. Is it possible this sound is normal for this kind of unit? If not, can we say anything about what I can expect going forward, like how long it may be before it stops cooling? AC Sound.m4v
  11. Had this exact call today. Invaluable info here!
  12. fcm350
    Tech sheet
    Thank you.
  13. Last week
  14. Captain Dunsel
    Tech sheet
    Uses the same tech sheet as this model: May have some similarities to Parts of this manual:
  15. Manufacturer: Fridgadare Type of Appliance: Refrigerator Model Number: LGHS2665KF0 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Looking for tech sheet and service manual for LGHS2665KF0. Thanks
  16. Centre St-Exupery
    Kenmore/Samsung washer
    There's stuff here: Get help with your Kenmore 592-49612 https://app.mycentriq.com/product-support/Kenmore/592-49612/62501a31-12fa-404c-8392-4367a1e59039 @Samurai Appliance Repair Manthere are PDFs to download on the page if you could load them please
  17. Robert Couchman
    The problem keeps recurring, soft ice cream, no ice cubes, etc. I did a manual defrost, pulled the heater sensor pigtail, the black cylinder (thermistor?) measures aroune 2K ohms at room temperatur, the othe device is open at room temp, heater shows 53 ohms, what do you suggest?
  18. Uses the same one as this model:
  19. May have some similarities to Parts of this manual: Uses the same mini manual as this model:
  20. mastertech011
    Maytag MAH5500BWW Neptune washer eats bearings
    Years too late for this one but I would have replaced the spinner support and used the correct bolt and washer. Im fixing to do mine not because it is making noise but because it is the 10th year since my last rebuild and the 20th year for the machine since I bought it new and I want to use it 10 more years. If I live that long I will be 80 and someone else can do the laundry then.. LOL
  21. Manufacturer: Kitchenaid Type of Appliance: Fridge/Freezer Model Number: KSRP25FSSS01 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes I found one post with most of the model number, but no tech sheet was found. I need tech sheet data to troubleshoot.
  22. Manufacturer: GE Type of Appliance: Refrigerator Model Number: pye23psdcss Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes GE pye23psdcss refrigerator service manual request Thank you
  23. Son of Samurai
    JGB760EEF2ES Service Manual
    I found this mini manual:
  24. GE JGB760EEF2 Range Mini Manual View File PUB 31-17087 Submitter Son of Samurai Submitted 06/24/2025 Category Appliance Repair Manual Pot Luck Supper
  25. Version 1.0.0
    2 downloads
    PUB 31-17087
  26. Son of Samurai
    Manual needed
    Domo, Captain!
  27. Speed Queen SFNBCFSP112TW01 Washer Troubleshooting Manual View File Pub 802740R4 Submitter Captain Dunsel Submitted 06/24/2025 Category Appliance Repair Manual Pot Luck Supper
  28. Thanks!
