Upcoming Events
Where: Online via Zoom
- Past hour
GE dryer dead
Koi Guy posted a blog entry in Koi Guy's Amazing Compendium of Timeless Appliantological Wisdom
This is a "box style" dryer- you know, it matches the front load washer. The complaint on my work order was "Sometimes works, sometimes doesn't. Now not working at all." I'm going in thinking a motor over-heating, maybe a motor relay on the mudderboard. Arrive to find the young lady and her newborn. She says, "My husband took it apart and can't figure it out. He thought it was a loose connection and it kinda worked for a little bit, but not really. And now it doesn't work at all." Yay me. Open the garage door to a machine that is 50% disassembled. Console off, lid off, front off, all the screws to the rear pane offl, terminal block, water valve... I'm talking he took off stuff that made no sense to take off. The water valve? In fairness he had everything laid out nicely and organized, and all the screws were next to said parts. Soooo, do I bail, or do I dig in??? Hmmmm... nice customer, nice and clean- well air conditioned house, neighborhood that I work in often, nice kitchen appliances, and matching washer. Sure, I'll have a look. Re-assemble unit and plug 'er on in for a maiden voyage. Dead. Go to the terminal block and find that the screw and lug is stripped on the neutral. And also the L2 screw and lug is stripped" Sheesh! Could it be that easy? Go to van and get parts and get the wiriing secured. Plug 'er in..... nada.... dang it.... Well, let's start looking. Bust out the skewed-matic and my reader glasses.... Let's see, L1 to board at the J101. Any voltage there? Nope. Hmmm. I see a "High- Limit Thermostat (Fuse Type)", what the heck is that? So I start looking for that fuse. It's not at the back near the terminal block. It's anywhere that I can see. I follow the wires and they go into the cabinet. Crap.... do I have to take this thing apart after I just put it back together. Yup.... Lo and behold, I find that the aforementioned "High- Limit Thermostat (Fuse Type)" is the dang Thernal Fuse on the heat canister. Huh? First time seeing that. If that thermal fuse opens- it doesn't just kill the heater- it kills power to the board! Lights out homie! In this case, I found that a terminal on the fuse was charred and not making connection to the biimetal inside. Makes sense now... intermittent working, and finally died. New fuse and new terminal and we back in bidness! IMG_7426.mov - Today
rich9403 joined the community
Serv started following Icemaker trouble - GE fridge model PWE23KSDESS
Glad to have found this community. We bought this refrigerator used and the icemaker is not working. Assuming the seller is honest and saying that it worked fine when they had it, I’m trying to troubleshoot. i’m curious about the little plastic flag at the back of the ice cube tray. It’s a spring loaded lever, but doesn’t come in contact with anything when I open or close the freezer drawer. I wonder if there is something missing, or what is the purpose of that plastic lever. There are no other icemaker settings on this fridge, except the mail disable button located on the door. Thank you for your help.
Martin Bonfiore joined the community
goliad started following Making Better Hose Clamp Pliers, Pt. 3 - A Prototype!
goliad commented on Rhubarb Tau's blog entry in Rhubarb Tau's Sloggy Vlog Blog Bog
Very interesting! I am curious to see the tool in action? Maybe you want to patent it first? -
doc007 joined the community
CullenG0 started following Bosch HIS8655U/01 Induction Range Tech Bundle
CullenG0 commented on Son of Samurai's file in Appliance Repair Manual Pot Luck Supper
derekg joined the community
Captain Dunsel started following Amana Dryer NED4700YQ1 Service manual needed
Captain Dunsel replied to ApplianceBushido's topic in Appliance Service Manual Requests Forum
appliance 2020 joined the community
ApplianceBushido started following Amana Dryer NED4700YQ1 Service manual needed
ApplianceBushido posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Amana Type of Appliance: Dryer Model Number: NED4700YQ1 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I have checked and downloaded the service bulletin at appliantology but I can’t find a service manual. The customer says it heats but doesn’t spin so I may be able to troubleshoot without one but I never like going out without knowing if I have access to a manual. I would appreciate any help locating one. Thank you. -
Son of Samurai replied to Evolve Custom's topic in Appliance Service Manual Requests Forum
Here you go: -
New Appliance Service Manual added: Blomberg WM98220SX 7178546900 Washer Tech Bundle
Blomberg WM98220SX 7178546900 Washer Tech Bundle View File Disassembly PUB 2060600727 Troubleshooting PUB 2060700330 Schematic PUB 2859299001 Submitter Son of Samurai Submitted 05/23/2025 Category Appliance Repair Manual Pot Luck Supper -
marv1 joined the community
GE Monogram ZISW420DRA freezer too cold fridge warm
Mr. mizer replied to WalterP12's topic in DIY Appliance Repair Help
I agree that it is air intrusion. After mucking around with it for years I think the new door seals and taping off the ice dispenser hole in the freezer door finally solved it. And no I don't think I have issues with the drain tube freezing up.- 37 replies
Captain Dunsel replied to SVeig's topic in DIY Appliance Repair Help
https://www.geappliances.com/appliance/AGITATR-COUP-WH1X1944 -
Looking for a service manual for the model T18ID900LP/11 I don't know how to change the water valves on an Ice Maker.
Son of Samurai replied to Oliver74's topic in Appliance Service Manual Requests Forum
Uses this bundle: -
Son of Samurai replied to David Hare's topic in Appliance Service Manual Requests Forum
Domo, Captain! -
New Appliance Service Manual added: Whirlpool EL88TRRWQ03 Freezer Wiring Sheet
Whirlpool EL88TRRWQ03 Freezer Wiring Sheet View File Pub Wiring Sheet - 1-82976 Submitter Captain Dunsel Submitted 05/22/2025 Category Appliance Repair Manual Pot Luck Supper -
Bosch HIS8055U/05 Service Manual Request
Son of Samurai replied to CullenG0's topic in Appliance Service Manual Requests Forum
Uses this bundle:- 1 reply
- 1
Son of Samurai replied to candpappliance's topic in Appliance Service Manual Requests Forum
Approved -- thanks, Vance! Apologies for the delay. -
LG S3MFBN Steam Closet Service Manual View File PUB MFL66987013 Submitter Vance R Submitted 05/21/2025 Category Appliance Repair Manual Pot Luck Supper
Bkoehn joined the community
- Yesterday
Evolve Custom posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Blomberg Type of Appliance: Washer Model Number: wm98220sx Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes I saw the manual for the wm98200, but it is not the same -
What Are These Capacitors Doing in This Convection Fan Motor Circuit?
Koi Guy commented on Son of Samurai's blog entry in Appliance Repair Tech Tips
Good stuff! -
citizenX replied to SVeig's topic in DIY Appliance Repair Help
Man that's a blast from the past! Yeah that's I think a WWA7xxx series or WWA8xxx or something like that? Not sure, it's been a while but not much is available for those anymore. When you say you have to push down on it to make it agitate, do you mean pushing down on the agitator? There is a splined coupler at the top of the transmission shaft that meshes with the top of the agitator (if I remember correctly) and if that or the splines in the agitator are stripped, it won't agitate. If you fill it without the agitator in place, does the transmission shaft rotate back and forth or only if you push down on the shaft? If the shaft isn't moving unless you push down on it, the transmission has a problem. If the shaft is moving back and forth, then either that coupler or the splines in the top of the agitator are stripped. -
kjolorenzen changed their profile photo
kerry H replied to kerry H's topic in DIY Appliance Repair Help
The 1st switch is working when I close the lid. What isn't happening is the lid lock isn't getting a lock signal. I have use 3 different lid locks and they all do the same thing. I push the cycle/start knob and it beeps once and nothing happens. Eventually it will be two times (same as the pause cycle beeps) but noting more happens. If I don't close the lid lock and push the cycle/start knob, it beeps 3 times (assume indicating the lid is open). I am not sure what else the controller is looking for before it will lock the lid and start the cycle. -
Hey Vance it’s showing that I don’t have permission to view the file? -
Criterion Fridge Service manual or tech sheet needed.
tfre replied to ExiledRonin117's topic in Appliance Service Manual Requests Forum
KitchenAid, Jenn-Air, Whirlpool Undercounter Ice Maker Recirculation Pump Noise & Low Ice Production Service Pointer
normukha commented on MarcusF's file in Appliance Repair Manual Pot Luck Supper
CullenG0 posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Bosch Type of Appliance: Induction Range Model Number: HIS8055U/05 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Respectfully request the Service Manual if available. Thank you in advance.
Blog Entries
0 comments
Topics
Son of Samurai · Started
