  1. Today
  2. Update on this - Repair Clinic now lists only 1 motor/pump for this model, from what I have been told this should not be the problem. Recently I was told they used one pump/motor for models prev to 1988, and a different one after that. My DW should be in the later group, I think built around 1980. I was told it sounds like a faulty timer - I looked at the number it was supposed to do on Repair Clinic, they don't have it - found it new on ebay - same model number as Repair Clinic had listed as, the 672 - I noticed that I couldn't get that previously at RC, so that order had been cancelled, and the timer I had bought of ebay shows as numbers WD21X626, WD21X0626,271598. Were these 3 latter model numbers NOT compatible with the GSD940-L-02? Is that why the water pumps out, then the motor continues to run during the drying cycle?
  3. Hi everyone, I’m working on a Kenmore French-door fridge (model 970-705036) and the water dispenser isn’t working. Here’s what I’ve checked so far: Hi everyone, I’m working on a Kenmore French-door fridge (model 970-705036) and the water dispenser isn’t working. Here’s what I’ve checked so far: Replaced the entire water valve assembly Verified that the main inlet valve gets 120V when pressing the paddle (I hear the solenoid click) But no water comes out of the dispenser Also, the water filter LED is on I'm suspecting it might be a clogged or faulty water filter, but before I order a new one, I wanted to confirm with you guys — could it still be a bad filter housing or something else I’m overlooking? Thanks in advance for any help!
  4. Hey everyone, I’m working on an LG electric range (model LSC883WS) and the oven won’t heat on Bake. Here’s what I’ve confirmed: 240V confirmed at the terminal block Both black and red legs show 120V to ground Bake relay clicks when I start a bake cycle But at the element terminals, I only get 120V from each end to ground, and 0V across the two terminals Bake element tests good for continuity All wiring looks intact, but I'm still not getting 240V across the element
  5. Manufacturer: Whirlpool Type of Appliance: Dishwasher Model Number: Wdf331pahs1 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I
  6. Given the age of your Whirlpool (14 years), it's right on the edge of what’s worth throwing parts at. If the freezer’s cold but the fridge is warm, it’s likely an airflow issue—either a failed evaporator fan, blocked vent, or defrost system problem (frost buildup blocking air to the fridge). The defrost thermostat and wiring harness (WPW10290745) could be the culprit, but at $65–$200, you’re gambling on a maybe. Before spending that, check if the evaporator fan is running and make sure there’s no ice buildup blocking vents. If the fan’s dead or there's frost, it might be worth replacing the part—but only if you're comfortable with DIY. Otherwise, you’re better off putting that money toward a new unit.
  7. Yesterday
  8. Model Number: PS950SF2SS Brand: GE Age: More than 10 years My trouble-free GE range now has a problem. The center element of the 12-inch 3-element burner is not heating. A repair shop came out and replaced the burner. The middle element is still not heating. They say the problem is the control panel. PROBLEM: the control panel is no longer available, not even pre-owned on Ebay. Questions: 1 - is there a source for this item [part # WB27X21437] that I haven't thought of? 2 - is there a possible setting change or relay replacement that could address this issue? [note, it took the techs a couple tries to wire the burner into the board correctly] Thanks -- Bob
  9. S & E Appliance
    DLE3400W flow sense issue.
    Posted in wrong forum, sorry about that
  10. Koi Guy
    until
    I'm in.
  11. Captain Dunsel
    Need service manual
    Here you go: Uses this mini manual:
  12. Manufacturer: GE Type of Appliance: Washer Model Number: GFW650SPN2SN Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need service manual for GFW650SPN2SN Thanks!
  13. Manufacturer: LG Type of Appliance: DRYER Model Number: DLE3400W Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Hi all, I know this has been topic beaten to death, but I’ll through a few more blows.I watched the workshop on this flow sense but this one is different as they show no “Flow Sense”on the wiring diagram. Ran the install test with vent connected and disconnected. Failed both. Inspected blower assembly and all is clear, drum turns easy. Lint screen passes water. I’m assuming they use a temperature to determine blockage. Question is, is it the sensor on blower housing? Or is it a difference between two sensors? The manual only talks about clogged venting, never really shares any info on sensors. LG says you can turn this off. Timed dry & wrinkle care. It should show on or off. Mine showed 1 or 0, which digitally could be on or off. Appreciate any tips.
  14. Uses this mini manual: You should be able to use this service manual:
  15. Manufacturer: GE Type of Appliance: 48 Inch Refrigerator Model Number: psb48ysnhss Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes hey guys this is a fairly new unit. 48inch GE Profile. I need a service manual please.
  16. Uses the same one as this model:
  17. Manufacturer: GE Type of Appliance: Refrigerator Model Number: PYE22KBLCTS Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Customer is getting condensation on the left side refrigerator wall inside fridge. I’m looking for the tech sheet to see if there is supposed to be a heater for the IM air duct or if it is bad insulation inside the wall. Thanks!
  18. Those service manuals are published the year the model family came out. I don't know of any definitive way to find them. I googled the part# and found this:
  19. Manufacturer: Electrolux / frigidaire ? Type of Appliance: refrigerator Model Number: GRSC2352AF0 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Could only find tech sheet download for it from a different model # but I believe the tech sheet offered in the download section will work for this model # , what I really need is the service repair manual if there is one. The main control board underneath the front of this model is a little different than the normal ones you can just take out easily. . Trying to find out the removal process for the main board located behind the refrigerators lower kick plate ??
  20. Uses the schematic and error codes doc from this bundle:
  21. Bosch SHEM78WH5N/32 Dishwasher Service Manual View File PUB 58300000183868 Submitter Son of Samurai Submitted 06/04/2025 Category Appliance Repair Manual Pot Luck Supper
  22. Version 1.0.0
    1 download
    PUB 58300000183868
  23. Uses this manual: And the schematic in this bundle:
  24. Here you go:
  25. Sub-Zero UW-24 Wine Cooler Service Manual View File PUB 7040748 Rev A September 2016 Submitter Son of Samurai Submitted 06/04/2025 Category Appliance Repair Manual Pot Luck Supper
  26. Version 1.0.0
    0 downloads
