  2. Very interesting! I am curious to see the tool in action? Maybe you want to patent it first?
  3. Thank you so much!
  4. Today
  5. Captain Dunsel
  6. Manufacturer: Amana Type of Appliance: Dryer Model Number: NED4700YQ1 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I have checked and downloaded the service bulletin at appliantology but I can’t find a service manual. The customer says it heats but doesn’t spin so I may be able to troubleshoot without one but I never like going out without knowing if I have access to a manual. I would appreciate any help locating one. Thank you.
  7. Son of Samurai
    Here you go:
  8. Blomberg WM98220SX 7178546900 Washer Tech Bundle View File Disassembly PUB 2060600727 Troubleshooting PUB 2060700330 Schematic PUB 2859299001 Submitter Son of Samurai Submitted 05/23/2025 Category Appliance Repair Manual Pot Luck Supper
  9. Version 1.0.0
    8 downloads
  10. I agree that it is air intrusion. After mucking around with it for years I think the new door seals and taping off the ice dispenser hole in the freezer door finally solved it. And no I don't think I have issues with the drain tube freezing up.
  11. https://www.geappliances.com/appliance/AGITATR-COUP-WH1X1944
  12. Son of Samurai
    Domo, Captain!
  13. Whirlpool EL88TRRWQ03 Freezer Wiring Sheet View File Pub Wiring Sheet - 1-82976 Submitter Captain Dunsel Submitted 05/22/2025 Category Appliance Repair Manual Pot Luck Supper
  14. Uses this bundle:
  15. Son of Samurai
    Approved -- thanks, Vance! Apologies for the delay.
  16. LG S3MFBN Steam Closet Service Manual View File PUB MFL66987013 Submitter Vance R Submitted 05/21/2025 Category Appliance Repair Manual Pot Luck Supper
  17. Yesterday
  18. Manufacturer: Blomberg Type of Appliance: Washer Model Number: wm98220sx Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes I saw the manual for the wm98200, but it is not the same
  19. Good stuff!
  20. Man that's a blast from the past! Yeah that's I think a WWA7xxx series or WWA8xxx or something like that? Not sure, it's been a while but not much is available for those anymore. When you say you have to push down on it to make it agitate, do you mean pushing down on the agitator? There is a splined coupler at the top of the transmission shaft that meshes with the top of the agitator (if I remember correctly) and if that or the splines in the agitator are stripped, it won't agitate. If you fill it without the agitator in place, does the transmission shaft rotate back and forth or only if you push down on the shaft? If the shaft isn't moving unless you push down on it, the transmission has a problem. If the shaft is moving back and forth, then either that coupler or the splines in the top of the agitator are stripped.
  21. The 1st switch is working when I close the lid. What isn't happening is the lid lock isn't getting a lock signal. I have use 3 different lid locks and they all do the same thing. I push the cycle/start knob and it beeps once and nothing happens. Eventually it will be two times (same as the pause cycle beeps) but noting more happens. If I don't close the lid lock and push the cycle/start knob, it beeps 3 times (assume indicating the lid is open). I am not sure what else the controller is looking for before it will lock the lid and start the cycle.
  22. candpappliance
    Hey Vance it’s showing that I don’t have permission to view the file?
  23. nice cool video how to put this icemeker in service mode and test all the components step by step
  24. Manufacturer: Bosch Type of Appliance: Induction Range Model Number: HIS8055U/05 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Respectfully request the Service Manual if available. Thank you in advance.
  25. I have a Kenmore gas dryer (110.97583820) that I purchased new on Halloween 1994. We've been through a lot together in the past 30+ years. I have replaced the drive motor, the drive belt, the rear drum support wheels, and the door switch through the years but it has proven to be workhorse. I replaced the door switch with a questionable replacement but need to obtain a real OEM part to replace the 100% chinesium part (sold by a name parts house). I am not certain if that is relevant to the current problem but I will mention that twice I have opened the dryer door and the drum kept spinning until I tapped the switch. Currently the dryer drys clothes properly but runs from one cycle through the next until it completes the whole circuit (auto dry ---> timed dry ---> air dry) before stopping. What is the most-likely cause of this new behavior? The timer? The electronic control board? Something else? Thanks for your input!
  26. Thankyou !!!
