New Appliance Service Manual added: Whirlpool Gas Freestanding Ranges with Direct Spark Ignition (DSI) Control Service Pointer: Spark but no Ignition
File Name: Whirlpool Gas Freestanding Ranges with Direct Spark Ignition (DSI) Control Service Pointer: Spark but no Ignition
File Submitter: Samurai Appliance Repair Man
File Submitted: 25 Oct 2013
File Category: Appliance Repair Manual Pot Luck Supper
(DSI) Control All Code Dates
Concern:
Under certain circumstances the Bake burner may not ignite. Sparking
is taking place but flame is not established.
Cause:
• Wiring harness may be pinched at a location between the
Bake/Broil igniters and DSI Board.
• DSI Board mounting bracket may be contacting a solder joint on
back of the board.
• Positioning of Igniter and gas burner igniter ports may be out of
adjustment.
• Igniter (Electrode) deterioration
Technical Service Pointer #: W10622771
Release Date: October, 2013
Click here to download this file
  • 3 months later...
Another good thing to check is a bad ground wire. You can add a better ground from the burner air flap to the chassis. Would love to download the service pointer
