Team Samurai Samurai Appliance Repair Man Posted November 15, 2014 Team Samurai Posted November 15, 2014 File Name: Maytag and Whirlpool Electric Freestanding Ranges with Induction Cooktops - Cooktop May Not Operate When Using the OvenFile Submitter: Samurai Appliance Repair ManFile Submitted: 15 Nov 2014File Category: Appliance Repair Manual Pot Luck SupperModels:MIR8890AS0, YMIR8890AS0, WFI910H0AS0 & YWFI910H0AS0Evernote enex ZIPClick here to download this file
TotalPro Posted November 16, 2014 Posted November 16, 2014 I am not able to download this file because windows does not recognize the enex. file extension.
Team Samurai Samurai Appliance Repair Man Posted November 16, 2014 Author Team Samurai Posted November 16, 2014 Windows does recognize the ZIP extension so that should work. Can you post a screen shot of the error you're seeing? That would help me troubleshoot this problem for you.
Team Samurai Samurai Appliance Repair Man Posted November 16, 2014 Author Team Samurai Posted November 16, 2014 And read this blog post that explains these files: Everything you ever wanted to know about those new Evernote enex ZIP files in the Downloads section
TotalPro Posted November 16, 2014 Posted November 16, 2014 I did everything you said to do. I downloaded the file to my desktop. Opened the zip file and extracted the file to the desktop. When I go to open the file adobe reader will not open the file. It says Adobe reader could not open file when using enex because it is either not a supported file type or because the file has been damaged. I hope that helps.
BryanS Posted November 16, 2014 Posted November 16, 2014 (edited) It's a bummer these can't be downloaded to my phone. My win zip app won't unzip it. I guess I'll be doing a little research for a different app. Edited November 16, 2014 by BryanS
DurhamAppliance Posted November 16, 2014 Posted November 16, 2014 Bryan, what phone are you using? Lifierro, did you read the blog??
Budget Appliance Repair Posted November 17, 2014 Posted November 17, 2014 (edited) Same problem here. No problem unzipping/extracting the file but Windows XP can't open a ".enex" file. My thought was you have to download and install Evernote to read these files, I searched support help at Evernote to see if I could find something to install to be able to open .enex files without Evernote but didn't come up with anything. Support came up with tons of stuff but nothing to do with what I was searching for. NOT IMPRESSED! I don't understand why you would force someone to download Evernote to read help files - why can't they just be uploaded here as a standard .PDF file that virtually every computer can read and open? When you unzip the zipped file it creates a new folder with the same name as the zip file without the .zip extension, (the folder has .enex at the end which doesn't do anything as you can name a folder anything you want). The file insided the folder then has no extension at all - most likely because the name is too long and it cuts it off because a filename can only be 87 characters in Windows XP, (don't know if this is completely correct but this is the filename that is left inside the folder - "Maytag and Whirlpool Electric Freestanding Ranges with Induction Cooktops - Cooktop May", 87 characters long without an extension). I removed some more of the long name and added the .enex extension and Windows still doesn't know how to open it. I did read in the Evernote help/support that you can export your Evernotes as an .enex or .html - when exported as an .html it creates a webpage with all the elements of your notes in it which then the file would most likely contain the extracted .PDF file that you're trying to share with us. Here's the Evernote help support that mentions exporting as a .html file and explains the contents of a .enex file:http://blog.evernote.com/tech/2013/08/08/evernote-export-format-enex/ And how to get images or files out of Evernotes to use in other applications:https://evernote.com/contact/support/kb/#!/article/23194116 Edited November 17, 2014 by Budget Appliance Repair
TotalPro Posted November 17, 2014 Posted November 17, 2014 Yes, I read your blog and followed the instructions but I cant read the files.
TotalPro Posted November 17, 2014 Posted November 17, 2014 I found a way to read the evernote files. Go to www.evernote.com/download and dowlnload a free version of this application.
DurhamAppliance Posted November 17, 2014 Posted November 17, 2014 Come on Brother Lifierro... from the blog : "Using these special files is easy: just download them like you would any other file from the Downloads section and unzip them. Then open the evernote app on your pooter and select File > Import Notes... from the top menu."
Budget Appliance Repair Posted November 17, 2014 Posted November 17, 2014 Durham, if you don't have or want the Evernote app then that won't work. The userfriendly way for the Samurai to share what he has in Evernotes in a way that everyone can see it.https://evernote.com/contact/support/kb/#!/article/23194116 How can I get images or files out of Evernote for use in other applications?If a note contains a file (like a PDF, image or other file) and you'd like to save a copy of this file to your computer for use in other applications, simple right-click the file and choose "Save As..." and choose the location where you'd like to save the file. You may also want to change the filename since, depending upon how the file was added, the filename may be a series of letters and numbers generated by the Evernote application when the file was added.
Team Samurai Samurai Appliance Repair Man Posted November 17, 2014 Author Team Samurai Posted November 17, 2014 (edited) Some of these bulletins are multi-page and then put together and sequenced properly into a single Evernote. So for one of these Evernote bulletins that contains 5 scanned PDFs, I'd have to do 5 "save-as" operations and then round up those PDFs out of the sea of other PDFs on my computer, zip, and upload. Exporting them as enex files exports all the scanned PDFs in that note and preserves sequence and annotation, all in a single click. Then I need only compress a single file and upload. Which would you do? If you don't want Evernote, even the free version, fine-- stay in the 20th Century and don't get it. Edited November 17, 2014 by Samurai Appliance Repair Man
DurhamAppliance Posted November 17, 2014 Posted November 17, 2014 Bro Budget, I wasn't commenting on the pros and cons of the enex file only that the instructions were clear what needed to be done to retrieve the files.
Spannerwrench Posted November 17, 2014 Posted November 17, 2014 I personally like and use Evernote daily, as well as all of my techs. There's a lot more you can do with a PDF now besides just read it. Using Evernote with PDF's is a great tool. That piece of paper, PDF, is now searchable in a second, you can hand write on it which is searchable, and many other benefits. I agree with the Samurai, he's not forcing you to do anything, just opening up new doors for you. I've been doing this for a long time and I remember not getting service pointers and things until a year after they were released, if I ever got them. Whether or not we were manufacture authorized. Now you can get them at the click of the mouse or by simply typing in a model number and all of the notes you've taken populate. You can also do so much more with the PDF besides just reading it like a piece of paper. Just a few of my thoughts... 1
Spannerwrench Posted November 20, 2014 Posted November 20, 2014 I also forgot to mention, you can install the free version of Evernote, and if you prefer, right click on the note and convert the note not a PDF for you viewing pleasure.
