    222
    739
    368,224
Pop Quiz: What's Wrong with This Defrost Drain?
Son of Samurai
If you cracked open a freezer and saw the defrost drain looking like this, what would be your immediate reaction?
Do you see what the problem is? Take a closer look...
Have you figured it out? The deal with this defrost drain is...
There is no problem. This is a clear, perfectly normal-looking defrost drain. You can see a little evidence of some water pooling and freezing, but the amount is well within acceptable limits. Based on a visual inspection, there is no issue with this drain.
Why post a trick question like this? To highlight the importance of being able to recognize when a component is in acceptable condition. In other words, when a component is in-spec.
This is an example of an implicit specification -- in other words, a specification that is not necessarily given by a manufacturer because it's something you should simply know as part of being a technician. It's vital to be aware of the specifications we're supposed to know without being told, such as what a clear defrost drain should look like. A lot of these things simply come with experience. Or, of course, from studying the copious amounts of awesome info here at Appliantology.
If you want to get in on all the latest game-changing tech info and swap knowledge with other sharp techs, click here to become a premium member today.
  • Like 10
  • Thanks 2
1 Comment
Got it immediately, old school Jedi mind trick did not work young Skywalker.
Link to comment
