  2. Manufacturer: Bosch Type of Appliance: Dryer Model Number: WTVC6330US/11 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Looking for tech manual, couldn't find any. Thanks
  3. Today
  4. I've also been hunting for a substitute for the GE WR09X10053 part# GE says is the correct replacement for my FCM5DMCWH. I had little or no luck other than what looked to be discolored, very used-looking parts on eBay. After seeing QKCAM's post, I bought the Amazon WR50X10085. But when I attempted to install it, I hit a snag. The original thermostat on mine was screwed into the back of the temperature adjustment knob's mounting plate with two screws that went through 2 holes into plastic posts on the back of that plate. My problem is that the Amazon WR50X10085 has no mounting bracket at all. So the only thing holding a device that's controlling full amperage 120v power would be the friction press-fit of the shaft into the freezer's control knob. That doesn't seem safe to me. My freezer's original thermostat was labeled "CS6448N" and "WPF27S-103-032"). There was no significant number of visible threads on its shaft. So I didn't see any obvious way to get the stand-off mount with the screw holes off the original thermostat and onto the WR50X10085. The 10085's shaft is threaded. It looked like the tab the knob hits to turn the freezer off prevents the spinner from rotating 360 degrees to unscrew the plate from the original one (if it is threaded) or to re-screw the old mounting plate onto the 10085. Just to further confuse the issue, I've since located a supposed "New old stock" WR09X10053 online. for nearly $100. It's pictures show it does have what looks like a nearly identical mounting plate - but that plate has no screw holes at all. So apparently the mounting for that thermostat has changed between revisions / serial numbers of this "Compact 5" freezer. Does anyone have any ideas of how to move the mounting plage from the CS6448N to the WR50X1008? Thanks in advance.
  5. Great tutorial, thank you Sam
  6. Yesterday
  7. Blake30
    Awesome breakdown enjoyed the article
  8. Manufacturer: LG Type of Appliance: Washer Dryer Combo Model Number: WM6998HBA Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Hi ya’ll. Rolling the dice here but hoping someone can help with providing a service manual and parts diagram for this unit. I understand it’s newer so information is limited. I did find a link for this unit with a manual but did not correspond. This was confirmed with a visit to the customer’s and schematic is as follows.
  9. GreenhornDabbler
    Whirlpool WOC54EC0ASOO errors
  10. Thank you
  11. Last week
  12. Thank you! Have a nice weekend
  13. Uses the same tech sheet as this model:
  14. Manufacturer: Frigidaire Type of Appliance: Dishwasher Model Number: GDPP4517AF0A Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes May I please have the tech sheet or service manual for this unit, couldn’t find one using the usual searches. Thank you!
  15. Son of Samurai
    Frigidaire service manual req
    Domo, Captain!
  16. Frigidaire FCFE2425AS Range Service Data Sheet and Parts List View File Pub Service Data Sheet 808532305 Pub Parts List 5995724373 Models: FCFE2425AS FCFE2425AW Submitter Captain Dunsel Submitted 06/06/2025 Category Appliance Repair Manual Pot Luck Supper
  17. I checked door switch per video and had zero ohms at 3-4. Purchased a new door switch and it did not have any ohms 3-4. Has anyone else ran across this.
  18. JSMequipmentservices
    Anything yet on this seeing more of these things out there
  19. Captain Dunsel
    LG dishwasher
    See if you can use this one:
  20. Manufacturer: LG Type of Appliance: Dishwasher Model Number: LDP7708BD Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Tech sheet pls
  21. I need it too
  22. 86 that I found it part number W10476805 got the tech sheet here. thanks anyway!
  23. Manufacturer: Naytag Type of Appliance: Refrigerator Model Number: MBF1953YEW3 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Service manual or tech sheet. I need parts list as well thermistor and defrost Tstat not listed on Dey. thank you
  24. Hello, my name is Shaneice and I’m a Talent Acquisition Partner at Electrolux Group. We are actively seeking skilled appliance repair technicians across multiple locations nationwide to join our growing team! If you're looking for a stable career with competitive benefits, growth opportunities, and a supportive work environment, this a great opportunity for you. What We Offer: ✔ Competitive Salary + Commission Opportunities ✔ Paid Commute & Company-Provided Van, Equipment, and Parts ✔ Monday-Friday Schedule – No Weekends! ✔ Day-One Benefits & Employee Discounts ✔ Comprehensive Training & Career Advancement ✔ Work with Cutting-Edge Technology & Industry-Leading Equipment Position Overview: We are hiring Branded Service Technicians to provide in-home appliance repairs on washers, dryers, refrigerators, dishwashers, ovens, and ranges. This role requires technical expertise, customer service skills, and problem-solving abilities to ensure quality repairs and customer satisfaction. Required Qualifications: 2+ years’ experience with electro-mechanical repair or equivalent education experience Ability to move large appliances and lift to 50lbs. High School Diploma or GED Must have and maintain a satisfactory driving record in accordance with Electrolux policy. Professional oral and written communication skills. Enjoys working within a growing organization and team oriented. Ability to successfully complete a background check Preferred Qualifications: Experience with home appliance repairs Proficient in Sealed Air Systems or EPA refrigeration license preferred Open Locations: We are hiring across multiple locations nationwide! Check out our current openings here: Richmond, CA Vallejo, CA Vista/Oceanside, CA Washington, DC Miami, FL Minnesota, MN Charlotte, NC Cleveland/Akron, OH Columbus/Cincinnati, OH Charleston, SC Nashville, TN Beaumont, TX Kyle/San Marcos/New Braunfels/Lockhart, TX Fort Worth, TX Virginia Beach, VA Woodbridge, VA Kenosha/Pleasant Prairie, WI Ready to take the next step? Apply today and start your career with us! If you have any questions or would like more details, feel free to reach out. I’m happy to help guide you through the application process. Looking forward to connecting with you soon!
  25. Manufacturer: Franke Type of Appliance: Coffee Machine Model Number: A400 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes This might be a long shot. But I'm looking for any technical info i can get for the A400 machine. I recently fixed one at our local airport, but I have no idea how i did it. I'm flying blind on these things. But I have another one on the schedule today.
  26. The "flag" will stop ice production when the bucket is full. There should also be an on/off switch on the icemaker. Make sure water is on. Confirm there is a filter or bypass plug in the filter housing. There should be a tech sheet in or near the rear panel by the compressor, there may be an Icemaker test mode in it, I cant remember as Ive been using bluetooth to diagnose these units for years now. Keep in mind, the icemaker may have just pooped out on you, wierder things have happened.
  27. @NoahB24 Yes!
  28. Version 1.0.0
    2 downloads
  29. Captain Dunsel
    Uploading service data sheet, parts list and waiting on approval:
