Upcoming Events
Where: Online via Zoom
- Past hour
swapped out relay control board. N/C. the only wires I haven't viewed are the connects to the heating elements. any possibility it could be the sensor in the upper right corner of the oven ? 00425301
- Today
Catfish joined the community
Son of Samurai started following Loading Meter Resurrects a Dead Dryer
Son of Samurai posted a blog entry in Appliance Repair Tech Tips
An interesting topic came up here in the Appliantology forums a little while back: The tech was working on an electric dryer that was DOA -- no lights, no response to button presses. He put his multimeter to the LoZ setting (as you should always do when making AC voltage measurements!), and he started checking for the power supply to the appliance at the terminal block. Here's what he got: L1 to N: 0 VAC L2 to N: 120 VAC L1 to L2: 20 VAC -- and while the meter leads are held on L1 and L2, the dryer UI lights up! Huh? What's going on here, both with the strange voltage reading from L1 to L2, and with the dryer coming to life while that voltage measurement is being taken? Let's crack out the schematic and find out. Here's the dryer schematic with the power supply to the board marked up. As you can see, the board's power supply is L1 and Neutral. There's no switch in either Line or Neutral going to the board -- the board is hardwired to its power supply. That, combined with the fact that, even when we measure at the terminal block, we get 0 VAC from L1 to Neutral, seems to indicate that we're missing L1, probably due to an open in the wall outlet or the house wiring. But how then is the board coming to life during our L1 to L2 voltage measurement? Well, let's look at what we're doing on the schematic when we perform that voltage measurement. How does connecting the meter like this cause the board to come to life? It's because we are connecting L2 to the L1 side of the circuit through the loading meter. Here's a simplified drawing of what's happening: We are effectively creating a series circuit with the loading meter and the control board. This also explains the weird voltage reading we got measuring from L1 to L2 -- that's how much voltage was being dropped across the loading meter. This is what that circuit looks like, drawn out as a line diagram. So there you have it -- a weird problem with whacky symptoms that turns out to have a simple solution! All of this came from a missing L1 at the wall outlet, the kind of thing you can easily catch by taking a measurement right at the outlet with a loading meter. Want to get in on the action? Join the Brotherhood of Techs at Appliantology. Appliantology.org is a cultivated, private community of techs. Get solid tech advice from working, professional techs and business owners. Avoid the endless noise and guesswork thrown at you from groups on social media. Download the service manuals, tech sheets, and service bulletins you need to git 'er done. Join the Brethren in the Craft right now with our membership options at Appliantology and see how it can help you in your business starting today. -
mkam5 joined the community
GE PFE28PELDDS Service Man Request
CullenG0 replied to CullenG0's topic in Appliance Service Manual Requests Forum
Most appreciative Sir - Thank you! -
Kvberry13 started following FULL Service Manual Needed
Kvberry13 replied to CGA's topic in Appliance Service Manual Requests Forum
Encompass has the manual now. Posted in English. -
Jeffrey Walter joined the community
K0SE500ESS20 Kitchenaid Wall Oven Service Manual Needed
Captain Dunsel replied to David1's topic in Appliance Service Manual Requests Forum
Here you go: -
Captain Dunsel started following GE PFE28PELDDS Service Man Request
Captain Dunsel replied to CullenG0's topic in Appliance Service Manual Requests Forum
Uses the same mini manual as this model: -
CullenG0 started following GE PFE28PELDDS Service Man Request
CullenG0 posted a topic in Appliance Service Manual Requests Forum
Manufacturer: GE Type of Appliance: Refrigerator Model Number: PFE28PELDDS Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Respectfully request this manual if anyone has it. Thank you in advance. -
David1 replied to David1's topic in Appliance Service Manual Requests Forum
@Captain DunselSorry yes thats the one but I need SM, not tech sheet -
Kvberry13 started following Service manual for Five Star Range
Captain Dunsel started following K0SE500ESS20 Kitchenaid Wall Oven Service Manual Needed
Model number is wrong! Could it be KOSE500ESS02? If so it uses this tech sheet! -
Krystal Ivie joined the community
David1 started following K0SE500ESS20 Kitchenaid Wall Oven Service Manual Needed
David1 posted a topic in Appliance Service Manual Requests Forum
Manufacturer: KitchenAid Type of Appliance: Wall Oven Model Number: K0SE500ESS20 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES K0SE500ESS20 Kitchenaid Wall Oven Service Manual Needed please -
patrickr57 joined the community
BWhiz joined the community
Looks like you can use this one:- 1 reply
- 2
I'm looking for the service manual
Son of Samurai replied to Rmeinholz's topic in Appliance Service Manual Requests Forum
Uses this manual: -
Range hood tech sheet
Son of Samurai replied to N1kon01's topic in Appliance Service Manual Requests Forum
Thanks, Cap! -
New Appliance Service Manual added: Whirlpool WVW51UC0FS3 Vent Hood Technical Manual
Whirlpool WVW51UC0FS3 Vent Hood Technical Manual View File Pub W10403806 - Rev B Submitter Captain Dunsel Submitted 05/20/2025 Category Appliance Repair Manual Pot Luck Supper -
Manufacturer: Samsung Type of Appliance: Stacked washer dryer unit Model Number: WH46DBH550EVAC Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Samsung WH46DBH550EV WH46DBH550EVAC stacked combo service manual request Thank you -
JONMORA joined the community
brihod8 joined the community
Jacob6785 joined the community
Dan Bass joined the community
I have a vintage General Electric “Three Speed Filter-Flo Washer 14” with “Infinite Water Level” and an “Assister” agitator which bottom ring is broken (see pictures below). Can’t find model number to look for compatible parts as I think model plate has been removed. The Assistor seems to work fine on the spin cycle, but hardly moves during wash cycle unless significant downward hand pressure is applied. Therefore presume / hope the broken plastic ring which is at the bottom of the Assistor Assembly is the problem and is an easy cheap fix. Can anyone visually identify model and / or compatible Assistor Assembly replacement ring and my presumption that the broken ring is the problem?
Sears Kenmore Whirlpool Oasis Dryers Service Manual and Tech Sheet
MisFixIt commented on Samurai Appliance Repair Man's file in Appliance Repair Manual Pot Luck Supper
- Yesterday
Captain Dunsel commented on Captain Dunsel's file in Appliance Repair Manual Pot Luck Supper
jkgilliland commented on Captain Dunsel's file in Appliance Repair Manual Pot Luck Supper
GE Monogram ZISW420DRA freezer too cold fridge warm
Outlaw appliance replied to WalterP12's topic in DIY Appliance Repair Help
I am a field technician and best I can tell this is an air leak issue. Have not been able to narrow it down. I taped off the dispenser, replaced the icing kit, replaced the board, all the dampers (2 lower ones failed anyways) I'm seeing the same thing with the ice build up in the return vent. My question would be for those of you who have done the styrofoam modification to allow more air are you having any issues with the drain tube freezing up? I've sealed up every nook and cranny I can see with refrigerator gum and silicone and the problem persists. I'm left believing that even though the doors appear to be sealing they are the issue. Any thoughts?- 36 replies
Service Manuel
Captain Dunsel replied to jkgilliland's topic in Appliance Service Manual Requests Forum
Uses the same one as this model:- 1 reply
- 1
Manufacturer: Maytag Type of Appliance: Freezer Model Number: MZF34X16DW06 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I guess i posted this in the wrong section prior. I need service Manuel. I got one i would consider close but the buttons are different. Downloaded MZF34X16DW01 I need MZF34X16DW06 Need to get into diagnosis mode.
Captain Dunsel replied to N1kon01's topic in Appliance Service Manual Requests Forum
On see a service manual.Uploading and waiting on approval:
Blog Entries
Topics
