  2. MrApplianceMatt
    What pins are you checking? If you're checking between 2 and 1 or 2 and 3 in connector J13 the you're going to see 120 VAC because J13-2 is Line to the lock. Try unplugging the lock connector at the board and checking for continuity between 2 and 3 in the harness connector with the lid closed. The lock mechanism is a high failure part.
  3. Today
  4. Manufacturer: LG Type of Appliance: Steam Closet Model Number: S3MFBN Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES Per home owner control works but unit wont work. Don't know the exact problem, I need the service manual to figure out this unit. Haven't worked on one, just like to be prepared with diagnostic and wiring schematic. Thank you.
  5. Yesterday
  6. Manufacturer: Thermadore Type of Appliance: Freezer Model Number: T18ID900LP/11 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Looking for a service manual for the model T18ID900LP/11 I don't know how to change the water valves on an Ice Maker.
  7. swapped out relay control board. N/C. the only wires I haven't viewed are the connects to the heating elements. any possibility it could be the sensor in the upper right corner of the oven ? 00425301
  8. An interesting topic came up here in the Appliantology forums a little while back: The tech was working on an electric dryer that was DOA -- no lights, no response to button presses. He put his multimeter to the LoZ setting (as you should always do when making AC voltage measurements!), and he started checking for the power supply to the appliance at the terminal block. Here's what he got: L1 to N: 0 VAC L2 to N: 120 VAC L1 to L2: 20 VAC -- and while the meter leads are held on L1 and L2, the dryer UI lights up! Huh? What's going on here, both with the strange voltage reading from L1 to L2, and with the dryer coming to life while that voltage measurement is being taken? Let's crack out the schematic and find out. Here's the dryer schematic with the power supply to the board marked up. As you can see, the board's power supply is L1 and Neutral. There's no switch in either Line or Neutral going to the board -- the board is hardwired to its power supply. That, combined with the fact that, even when we measure at the terminal block, we get 0 VAC from L1 to Neutral, seems to indicate that we're missing L1, probably due to an open in the wall outlet or the house wiring. But how then is the board coming to life during our L1 to L2 voltage measurement? Well, let's look at what we're doing on the schematic when we perform that voltage measurement. How does connecting the meter like this cause the board to come to life? It's because we are connecting L2 to the L1 side of the circuit through the loading meter. Here's a simplified drawing of what's happening: We are effectively creating a series circuit with the loading meter and the control board. This also explains the weird voltage reading we got measuring from L1 to L2 -- that's how much voltage was being dropped across the loading meter. This is what that circuit looks like, drawn out as a line diagram. So there you have it -- a weird problem with whacky symptoms that turns out to have a simple solution! All of this came from a missing L1 at the wall outlet, the kind of thing you can easily catch by taking a measurement right at the outlet with a loading meter. Want to get in on the action? Join the Brotherhood of Techs at Appliantology. Appliantology.org is a cultivated, private community of techs. Get solid tech advice from working, professional techs and business owners. Avoid the endless noise and guesswork thrown at you from groups on social media. Download the service manuals, tech sheets, and service bulletins you need to git 'er done. Join the Brethren in the Craft right now with our membership options at Appliantology and see how it can help you in your business starting today.
  9. Most appreciative Sir - Thank you!
  10. Encompass has the manual now. Posted in English.
  11. Here you go:
  12. Uses the same mini manual as this model:
  13. Manufacturer: GE Type of Appliance: Refrigerator Model Number: PFE28PELDDS Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Respectfully request this manual if anyone has it. Thank you in advance.
  14. @Captain DunselSorry yes thats the one but I need SM, not tech sheet
  15. Model number is wrong! Could it be KOSE500ESS02? If so it uses this tech sheet!
  16. Manufacturer: KitchenAid Type of Appliance: Wall Oven Model Number: K0SE500ESS20 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES K0SE500ESS20 Kitchenaid Wall Oven Service Manual Needed please
  17. Captain Dunsel
  18. Uses this manual:
  19. Son of Samurai
    Range hood tech sheet
    Thanks, Cap!
  20. Whirlpool WVW51UC0FS3 Vent Hood Technical Manual View File Pub W10403806 - Rev B Submitter Captain Dunsel Submitted 05/20/2025 Category Appliance Repair Manual Pot Luck Supper
  21. Manufacturer: Samsung Type of Appliance: Stacked washer dryer unit Model Number: WH46DBH550EVAC Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Samsung WH46DBH550EV WH46DBH550EVAC stacked combo service manual request Thank you
  22. I have a vintage General Electric “Three Speed Filter-Flo Washer 14” with “Infinite Water Level” and an “Assister” agitator which bottom ring is broken (see pictures below). Can’t find model number to look for compatible parts as I think model plate has been removed. The Assistor seems to work fine on the spin cycle, but hardly moves during wash cycle unless significant downward hand pressure is applied. Therefore presume / hope the broken plastic ring which is at the bottom of the Assistor Assembly is the problem and is an easy cheap fix. Can anyone visually identify model and / or compatible Assistor Assembly replacement ring and my presumption that the broken ring is the problem?
  23. I don't see the tech sheet for the gas model 110.77082600 Update: Found it on page 106 here.
  24. Last week
  25. Captain Dunsel
    It's the right tech sheet from servicematters!
  26. Sorry guys, I've had to take off and reload my pdf viewer. I think this is the right tech sheet.
  27. I am a field technician and best I can tell this is an air leak issue. Have not been able to narrow it down. I taped off the dispenser, replaced the icing kit, replaced the board, all the dampers (2 lower ones failed anyways) I'm seeing the same thing with the ice build up in the return vent. My question would be for those of you who have done the styrofoam modification to allow more air are you having any issues with the drain tube freezing up? I've sealed up every nook and cranny I can see with refrigerator gum and silicone and the problem persists. I'm left believing that even though the doors appear to be sealing they are the issue. Any thoughts?
  28. I don't understand why the controls are different. Those are the same controls as the first download. Not the controls on this machine.
  29. Captain Dunsel
    Service Manuel
