  2. Manufacturer: GE Type of Appliance: Refrigerator Model Number: PFE28PELDDS Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Respectfully request this manual if anyone has it. Thank you in advance.
  3. @Captain DunselSorry yes thats the one but I need SM, not tech sheet
  4. Today
  5. Model number is wrong! Could it be KOSE500ESS02? If so it uses this tech sheet!
  6. Manufacturer: KitchenAid Type of Appliance: Wall Oven Model Number: K0SE500ESS20 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES K0SE500ESS20 Kitchenaid Wall Oven Service Manual Needed please
  7. Captain Dunsel
  8. Uses this manual:
  9. Son of Samurai
    Range hood tech sheet
    Thanks, Cap!
  10. Whirlpool WVW51UC0FS3 Vent Hood Technical Manual View File Pub W10403806 - Rev B Submitter Captain Dunsel Submitted 05/20/2025 Category Appliance Repair Manual Pot Luck Supper
  11. Manufacturer: Samsung Type of Appliance: Stacked washer dryer unit Model Number: WH46DBH550EVAC Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Samsung WH46DBH550EV WH46DBH550EVAC stacked combo service manual request Thank you
  12. I have a vintage General Electric “Three Speed Filter-Flo Washer 14” with “Infinite Water Level” and an “Assister” agitator which bottom ring is broken (see pictures below). Can’t find model number to look for compatible parts as I think model plate has been removed. The Assistor seems to work fine on the spin cycle, but hardly moves during wash cycle unless significant downward hand pressure is applied. Therefore presume / hope the broken plastic ring which is at the bottom of the Assistor Assembly is the problem and is an easy cheap fix. Can anyone visually identify model and / or compatible Assistor Assembly replacement ring and my presumption that the broken ring is the problem?
  13. I don't see the tech sheet for the gas model 110.77082600 Update: Found it on page 106 here.
  14. Yesterday
  15. Captain Dunsel
    It's the right tech sheet from servicematters!
  16. Sorry guys, I've had to take off and reload my pdf viewer. I think this is the right tech sheet.
  17. I am a field technician and best I can tell this is an air leak issue. Have not been able to narrow it down. I taped off the dispenser, replaced the icing kit, replaced the board, all the dampers (2 lower ones failed anyways) I'm seeing the same thing with the ice build up in the return vent. My question would be for those of you who have done the styrofoam modification to allow more air are you having any issues with the drain tube freezing up? I've sealed up every nook and cranny I can see with refrigerator gum and silicone and the problem persists. I'm left believing that even though the doors appear to be sealing they are the issue. Any thoughts?
  18. I don't understand why the controls are different. Those are the same controls as the first download. Not the controls on this machine.
  19. Captain Dunsel
    Service Manuel
  20. Version 1.0.0
    0 downloads
  21. Manufacturer: Maytag Type of Appliance: Freezer Model Number: MZF34X16DW06 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I guess i posted this in the wrong section prior. I need service Manuel. I got one i would consider close but the buttons are different. Downloaded MZF34X16DW01 I need MZF34X16DW06 Need to get into diagnosis mode.
  22. Captain Dunsel
    On see a service manual.Uploading and waiting on approval:
  23. Manufacturer: Whirlpool Type of Appliance: Range Hood Model Number: Wvw51uc0fs3 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES Need tech sheet
  24. Uses the same one as this model:
  25. Manufacturer: Bosch Type of Appliance: Wall oven Model Number: HBN765AUC Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I'm looking for the repair manual for this machine. I have codes of f111, f112 and f113
  26. Manufacturer: Maytag Type of Appliance: Washing Machine Model Number: YMED7100DC0 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Looking for the tech sheet/service manual for Maytag dryer YMED7100DC0. The current substitute tech sheet for a similar model posted on Appliantology is not relevant.
  27. Captain Dunsel
    Service Manuel Request
    Those can be nightmares. Make sure the drain is clear and tilt the front legs up higher to give the defrost water a more of a chance to get out of the freezer before going back into the cooling mode!
  28. Captain Dunsel
    Service Data Sheet for Frigidaire SXS
    No bother to me.All you guys are saving my marriage as it keeps me from aggravating my wife.And I thank all of you!
